Datasheet Texas Instruments SN74AS832BDWR — Даташит
Серия | SN74AS832B |
Модель | SN74AS832BDWR |
Шестнадцатеричные 2-входовые драйверы ИЛИ 20-SOIC от 0 до 70
Hex 2-Input OR Drivers datasheet
PDF, 950 Кб, Версия: C, Файл опубликован: 1 янв 1995
![]() 26 предложений от 15 поставщиков Микросхема Логический чип, OR Gate 6Element 2IN Bipolar 20Pin SOIC T/R | |||
SN74AS832BDWR Texas Instruments | 200 ₽ | ||
SN74AS832BDWR Texas Instruments | от 557 ₽ | ||
SN74AS832BDWR Texas Instruments | от 598 ₽ | ||
SN74AS832BDWR Texas Instruments | по запросу |
Pin | 20 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | AS832B |
Width (мм) | 7.5 |
Length (мм) | 12.8 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Bits | 6 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 0.016 мА |
Рабочий диапазон температур | от 0 до 70 C |
Output Drive (IOL/IOH)(Max) | 15/-24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | AS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 9 нс |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74AS832B (5)
- SN74AS832BDW SN74AS832BDWR SN74AS832BDWRG4 SN74AS832BN SN74AS832BNE4
- Semiconductors > Logic > Gate > OR Gate
