Datasheet Texas Instruments OPA2682N — Даташит
Серия | OPA2682 |
Модель | OPA2682N |
SpeedPlus(TM) Двойной широкополосный буферный усилитель с фиксированным коэффициентом усиления и отключением 14-SOIC от -40 до 85
Datasheet
![]() 14 предложений от 14 поставщиков Микросхема Операционный усилитель, SpeedPlus(TM) Dual, Wideband, Fixed Gain Buffer Amplifier With Disable 14-SOIC -40℃ to 85℃ | |||
OPA2682N | 52 ₽ | ||
OPA2682N/2K5 Texas Instruments | 68 ₽ | ||
OPA2682N Rochester Electronics | 159 ₽ | ||
OPA2682N | 173 ₽ |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Evaluation Modules & Boards: DEM-OPA268XN
DEM-OPA268xN: Demonstration Fixture
Статус продукта: В производстве (Рекомендуется для новых разработок) - Evaluation Modules & Boards: DEM-OPA268XU
DEM-OPA268xU: Demonstration Fixture
- Video Operational AmplifierPDF, 107 Кб, Файл опубликован: 2 окт 2000
In analog technology, important advances are being made in video operational amplifiers, both in processing and in circuitry. The following article is concerned exclusively with explaining these key topics and the new circuit designs. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA2682 (4)
- OPA2682N OPA2682N/2K5 OPA2682U OPA2682U/2K5
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > High-Speed Op Amps (>=50MHz)
