Datasheet Texas Instruments CD54HC280F3A — Даташит
СерияCD54HC280
МодельCD54HC280F3A
Высокоскоростная КМОП-логика, 9-битный генератор четности/четности/проверка 14-CDIP от -55 до 125
CD54HC280, CD74HC280, CD54HCT280, CD74HCT280 datasheet
PDF, 708 Кб, Версия: D, Файл опубликован: 21 окт 2003
Микросхема Счётчик, Parity Generator/Checker 9Bit 14Pin CDIP Tube
CD54HC280F3A
3 135 ₽
CD54HC280F3A
4 296 ₽
CD54HC280F3A
CD54HC280F3A
Pin1414
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
МаркировкаCD54HC280F3A8607701CA
Width (мм)6.676.67
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Bits2
F @ Nom Voltage(Max)28 Mhz
FunctionParity
ICC @ Nom Voltage(Max)0.08 мА
Output Drive (IOL/IOH)(Max)5.2/-5.2 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
ТипOther
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)43 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
Серия: CD54HC280 (2)
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Counter/Arithmetic/Parity Function Products
На английском языке: Datasheet Texas Instruments CD54HC280F3A
