Datasheet Texas Instruments SN74ALS245ADWRE4 — Даташит
Серия | SN74ALS245A |
Модель | SN74ALS245ADWRE4 |
Восьмеричные шинные трансиверы с выходами с 3 состояниями 20-SOIC от 0 до 70
SN54ALS245A, SN54AS245, SN74ALS245A, SN74AS245 datasheet
PDF, 1.3 Мб, Версия: A, Файл опубликован: 13 янв 2003
![]() 10 предложений от 10 поставщиков Микросхема Логический контроллер, Bus XCVR Single 8CH 3-ST 20Pin SOIC T/R | |||
SN74ALS245ADWRE4 Texas Instruments | 12 ₽ | ||
SN74ALS245ADWRE4 Texas Instruments | 30 ₽ | ||
SN74ALS245ADWRE4 Texas Instruments | 39 ₽ | ||
SN74ALS245ADWRE4 Texas Instruments | 42 ₽ |
Pin | 20 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | ALS245A |
Width (мм) | 7.5 |
Length (мм) | 12.8 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Bits | 8 |
F @ Nom Voltage(Max) | 75 Mhz |
ICC @ Nom Voltage(Max) | 58 мА |
Рабочий диапазон температур | от 0 до 70 C |
Output Drive (IOL/IOH)(Max) | -15/24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 20SOIC: 132 mm2: 10.3 x 12.8(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | ALS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
tpd @ Nom Voltage(Max) | 10 нс |
- Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN74ALS245A (20)
- SN74ALS245A-1DW SN74ALS245A-1DWG4 SN74ALS245A-1DWR SN74ALS245A-1DWRG4 SN74ALS245A-1N SN74ALS245A-1NE4 SN74ALS245A-1NSR SN74ALS245ADBLE SN74ALS245ADBR SN74ALS245ADBRG4 SN74ALS245ADW SN74ALS245ADWG4 SN74ALS245ADWR SN74ALS245ADWRE4 SN74ALS245ADWRG4 SN74ALS245AN SN74ALS245AN3 SN74ALS245ANE4 SN74ALS245ANSR SN74ALS245ANSRG4
- Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
