Источники питания сетевого напряжения на DIN-рейке MEAN WELL
Datasheet Texas Instruments LMR61428XMMX/NOPB — Даташит
СерияLMR61428
МодельLMR61428XMMX/NOPB
Повышающий стабилизатор напряжения 8-VSSOP от 1,2 до 14 В, 2,85 А, 2 МГц, от -40 до 85
LMR61428 Low Input Voltage, Step-Up DC-DC Converter datasheet
PDF, 1.0 Мб, Версия: A, Файл опубликован: 4 апр 2013
16 предложений от 11 поставщиков
SIMPLE SWITCHER 1.2V to 14V, 2.85A 2MHz Step-Up Voltage Regulator 8-VSSOP -40℃ to 85℃
LMR61428XMMX/NOPB
59 ₽
T-electron
LMR61428XMMX/NOPB
80 ₽
TradeElectronics
LMR61428XMMX/NOPB
LMR61428XMMX/NOPB
Package TypeDGK
Industry STD TermVSSOP
Package QTY3500
МаркировкаSN1B
Width (мм)3
Length (мм)3
Thickness (мм).97
Max Height (мм)1.07
Duty Cycle(Max)70 %
Iq(Typ)0.1 мА
Package GroupVSSOP
Regulated Outputs1
Special FeaturesEnable
Switch Current Limit(Min)2.85 A
Switch Current Limit(Typ)2.85 A
Switching Frequency(Max)2000 kHz
Switching Frequency(Min)300 kHz
ТипConverter
Vin(Max)14 В
Vin(Min)1.2 В
Vout(Max)14 В
Vout(Min)1.24 В
  • Evaluation Modules & Boards: LMR61428XMMEVM
    LMR61428 Evaluation Module
  • Working With Boost Converters
    PDF, 159 Кб, Файл опубликован: 15 июн 2015
    This brief note highlights some of the more common pitfalls when using boost regulators. These includemaximum achievable output current and voltage, short circuit behavior and basic layout issues. It isassumed that the reader is familiar with the basic operation of a boost regulator.
  • Basic Calculation of a Boost Converter's Power Stage (Rev. C)
    PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
    This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
Серия: LMR61428 (2)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments LMR61428XMMX/NOPB
