Источники питания Keen Side
Datasheet Texas Instruments 5962-9668601QXA — Даташит
СерияSN54LVTH16245A
Модель5962-9668601QXA
16-битные шинные трансиверы ABT 3,3 В с выходами с 3 состояниями 48-CFP от -55 до 125
3.3-V ABT 16-BIT BUS TRANSCEIVERS WITH 3-STATE OUTPUTS--SN74LVTH16245A datasheet
PDF, 969 Кб, Версия: R, Файл опубликован: 1 ноя 2006
3.3-V ABT 16-Bit Bus Transceivers With 3-State Outputs 48-CFP -55 to 125
5962-9668601QXA
6 188 ₽
5962-9668601QXA
6 842 ₽
HXD Co.
5962-9668601QXA
Allelco
5962-9668601QXA
Pin48484848
Package TypeWDWDWDWD
Industry STD TermCFPCFPCFPCFP
JEDEC CodeR-GDFP-FR-GDFP-FR-GDFP-FR-GDFP-F
Package QTY1111
CarrierTUBETUBETUBETUBE
МаркировкаA5962-9668601QXAWDSNJ54LVTH16245
Width (мм)9.669.669.669.66
Length (мм)15.8815.8815.8815.88
Thickness (мм)2.482.482.482.48
Pitch (мм).635.635.635.635
Max Height (мм)3.053.053.053.05
Bits16
Package GroupCFP
Package Size: mm2:W x LSee datasheet (CFP) PKG
RatingMilitary
Schmitt TriggerNo
Technology FamilyLVT
VCC(Max)3.6 В
VCC(Min)2.7 В
RoHSSee ti.com
  • LVT Family Characteristics (Rev. A)
    PDF, 98 Кб, Версия: A, Файл опубликован: 1 мар 1998
    To address the need for a complete low-voltage interface solution, Texas Instruments has developed a new generation of logic devices capable of mixed-mode operation. The LVT series relies on a state-of-the-art submicron BiCMOS process to provide up to a 90% reduction in static power dissipation over ABT. LVT devices solve the system need for a transparent seam between the low-voltage and 5-V secti
  • LVT-to-LVTH Conversion
    PDF, 84 Кб, Файл опубликован: 8 дек 1998
    Original LVT devices that have bus hold have been redesigned to add the High-Impedance State During Power Up and Power Down feature. Additional devices with and without bus hold have been added to the LVT product line. Design guidelines and issues related to the bus-hold features, switching characteristics, and timing requirements are discussed.
  • Live Insertion
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • Introduction to Logic
Серия: SN54LVTH16245A (2)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
59629668601QXA, 5962 9668601QXA
На английском языке: Datasheet Texas Instruments 5962-9668601QXA
