Datasheet Texas Instruments REF5050AIDR — Даташит
СерияREF5050
МодельREF5050AIDR
3 ВµVpp/V Noise, 3 ppm/В°C Drift Precision Series Voltage Reference 8-SOIC -40 to 125
REF50xx Low-Noise, Very Low Drift, Precision Voltage Reference datasheet
PDF, 3.1 Мб, Версия: H, Файл опубликован: 13 июн 2016
64 предложений от 26 поставщиков
Опорный чип напряжения, Series Voltage Reference Low Noise, Very Low Drift, Precision VOLTAGE REFERENCE V-Ref Precision 5V 10mA 8Pin SOIC T/R...
Элрус
REF5050AIDR
от 103 ₽
T-electron
REF5050AIDR
125 ₽
REF5050AIDR
387 ₽
REF5050AIDR
от 458 ₽
Pin888
Package TypeDDD
Industry STD TermSOICSOICSOIC
Package QTY250025002500
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаREFA5050
Width (мм)3.913.913.91
Length (мм)4.94.94.9
Thickness (мм)1.581.581.58
Pitch (мм)1.271.271.27
Max Height (мм)1.751.751.75
Initial Accuracy(Max)0.05 %
Iout/Iz(Max)10 мА
Iq(Max)1000 uA
Iq(Typ)800 uA
LFN 0.1-10Hz(Typ)15 ОјVpp
Pin/Package8SOIC, 8VSSOP
Special FeaturesTRIM/NR pin
Temp Coeff(Max)3 ppm/ degree C
Temp Coeff(Typ)2.5 ppm/ degree C
VO5 В
Vin(Max)18 В
Vin(Min)5.2 В
  • Evaluation Modules & Boards: ADS8910BEVM-PDK
    ADS8910B SAR Analog to Digital Converter Evaluation Module
  • Evaluation Modules & Boards: ADS8900BEVM-PDK
    ADS8900B Fully-Differential Input, 20-Bit SAR ADC EVM Performance Demonstration Kit (PDK)
  • Evaluation Modules & Boards: ADS8920BEVM-PDK
    ADS8920B SAR ADC Evaluation Module
  • Evaluation Modules & Boards: ADS9120EVM-PDK
    ADS9120 SAR ADC Evaluation Module
  • Evaluation Modules & Boards: ADS1282EVM-CVAL
    ADS1282-SP Radiation Tolerant Evaluation Module
  • Low Power Input and Reference Driver Circuit for ADS8318 and ADS8319
    PDF, 1.5 Мб, Файл опубликован: 24 июн 2009
    The one size fits all approach to operational amplifiers is not effective. Every application has its own specific requirements that must be fulfilled. Appropriate selection of the op amp that drives an analog-to-digital converter (ADC) in a low-power application is a critical step. Most available low-power op amps trade off low-power features with other parameters such as bandwidth, settling t
  • Stacking the REF50xx for High-Voltage References
    PDF, 801 Кб, Файл опубликован: 29 май 2013
  • Semiconductors > Power Management > Voltage Reference > Series Voltage Reference
На английском языке: Datasheet Texas Instruments REF5050AIDR
