Datasheet Texas Instruments TPS73HD318PWPR — Даташит
Серия | TPS73HD3 |
Модель | TPS73HD318PWPR |
Стабилизатор напряжения с двойным выходом и малым падением напряжения 28-HTSSOP от -40 до 125 В
Dual Output Low-Dropout Voltage Regulator datasheet
PDF, 984 Кб, Версия: C, Файл опубликован: 13 май 1999
![]() 17 предложений от 14 поставщиков Чип стабилизации напряжения, TEXAS INSTRUMENTS TPS73HD318PWPR LDO Voltage Regulator IC, Fixed, 2 Output, 3.97V to 10V in, 80mV drop, 750mA out,... | |||
TPS73HD318PWPR Texas Instruments | 88 ₽ | ||
TPS73HD318PWPR Texas Instruments | 168 ₽ | ||
TPS73HD318PWPR Texas Instruments | 261 ₽ | ||
TPS73HD318PWPR Rochester Electronics | по запросу |
Pin | 28 |
Package Type | PWP |
Industry STD Term | HTSSOP |
JEDEC Code | R-PDSO-G |
Package QTY | 2000 |
Carrier | LARGE T&R |
Маркировка | PS73HD318 |
Width (мм) | 4.4 |
Length (мм) | 9.7 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
Точность | 5 % |
Fixed Output Options | 1.8,2.5,3.3 В |
Iout(Max) | 0.75 A |
Iout2 | 0.75 A |
Iq(Typ) | 0.34 мА |
Noise | 95 uVrms |
Output Capacitor Type | Ceramic |
Output Options | Adjustable Output,Fixed Output |
PSRR @ 100KHz | 6 дБ |
Package Group | HTSSOP |
Package Size: mm2:W x L | 28HTSSOP: 62 mm2: 6.4 x 9.7(HTSSOP) PKG |
Rating | Catalog |
Regulated Outputs | 2 |
Special Features | Enable |
Thermal Resistance ОёJA | 42 В°C/W |
Vdo(Typ) | 220 мВ |
Vin(Max) | 10 В |
Vin(Min) | 2.9 В |
Vout(Max) | 9.7 В |
Vout(Min) | 1.2 В |
Vout2(Max) | 3.3 В |
Vout2(Min) | 3.3 В |
- Technical Review of Low Dropout Voltage Regulator Operation And PerformancePDF, 284 Кб, Файл опубликован: 30 авг 1999
This application report provides a technical review of low dropout (LDO) voltage regulators and describes fundamental concepts including dropout voltage quiescent current and topologies. The report also includes detailed discussions of load/line regulation efficiency frequency response range of stable ESR and accuracy of LDO voltage regulators. - Fundamental Theory of PMOS LDO Voltage RegulatorsPDF, 66 Кб, Файл опубликован: 7 май 1999
This report presents a fundamental understanding on the theory of low-dropout voltage regulators using a PMOS FET as the pass element to adjust the output current to the load requirements. - PowerPAD Thermally Enhanced Package (Rev. H)PDF, 983 Кб, Версия: H, Файл опубликован: 6 июл 2018
Серия: TPS73HD3 (9)
- Semiconductors > Power Management > Linear Regulator (LDO) > Multi-Channel LDO
