Клеммные колодки Keen Side
Datasheet Texas Instruments OPA4134PA — Даташит
СерияOPA4134
МодельOPA4134PA
SoundPlus(TM) Высокопроизводительные операционные усилители звука 14-PDIP
OPAx134 SoundPlusв„ў High Performance Audio Operational Amplifiers datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 28 окт 2015
11 предложений от 10 поставщиков
Микросхема Операционный усилитель, SoundPlus(TM) High Performance Audio Operational Amplifiers 14-PDIP
OPA4134PA
44 ₽
Romstore
Россия, Беларусь
OPA4134PA
от 722 ₽
OPA4134PA
T-electron
OPA4134PA
Pin14
Package TypeN
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Width (мм)6.35
Length (мм)19.3
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рекомендуемая замена
ReplacementOPA4134UA
Replacement CodeF
Additional FeaturesBurr-Brownв„ў Audio
Approx. Price (US$)2.00 | 1ku
АрхитектураFET
CMRR(Min)(dB)86
CMRR(Typ)(dB)100
GBW(Typ)(MHz)8
Input Bias Current(Max)(pA)100
Iq per channel(Max)(mA)5
Iq per channel(Typ)(mA)4
Number of Channels(#)4
Offset Drift(Typ)(uV/C)2
Operating Temperature Range(C)-40 to 85
Output Current(Typ)(mA)40
Rail-to-RailNo
Slew Rate(Typ)(V/us)20
Total Supply Voltage(Max)(+5V=5, +/-5V=10)36
Total Supply Voltage(Min)(+5V=5, +/-5V=10)5
Vn at 1kHz(Typ)(nV/rtHz)8
Vos (Offset Voltage @ 25C)(Max)(mV)2
RoHSНе совместим
  • Remove the DC Portion of Signals with the ADS7817
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    Unwanted portions of a signal, such as a DC pedestal, can be difficult to reject in a single supply circuit. A DC pedestal voltage most typically appears at the output of an operational amplifier with a small signal riding on top of it. This pedestal voltage is required in the analog domain to insure that the small signal that contains the pertinent information never falls below the ground potenti
На английском языке: Datasheet Texas Instruments OPA4134PA
