Datasheet Texas Instruments SN74LVC139APWLE — Даташит
СерияSN74LVC139A
МодельSN74LVC139APWLE
Двойной декодер/демультиплексор с 2 на 4 строки 16-TSSOP от -40 до 85
SN74LVC139A datasheet
PDF, 1.1 Мб, Версия: O, Файл опубликован: 2 окт 2003
Кодеры, декодеры, мультиплексоры и демультиплексоры Dual 2 to 4-Line Decoder/Demltplxr
SN74LVC139APWLE
T-electron
SN74LVC139APWLE
Pin16
Package TypePW
Industry STD TermTSSOP
Width (мм)4.4
Length (мм)5
Thickness (мм)1
Max Height (мм)1.2
Approx. Price (US$)0.12 | 1ku
Bits(#)4
Channels(#)2
Configuration2:4
F @ Nom Voltage(Max)(Mhz)100
FunctionDecoder/Demultiplexer
ICC @ Nom Voltage(Max)(mA)0.01
Тип входаTLL/CMOS
Operating Temperature Range(C)-40 to 85
Output Drive (IOL/IOH)(Max)(mA)24/-24
Тип выходаCMOS
Package GroupTSSOP
Package Size: mm2:W x L (PKG)16TSSOP: 32 mm2: 6.4 x 5(TSSOP)
Schmitt TriggerNo
Technology FamilyLVC
ТипStandard
VCC(Max)(V)3.6
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
2.7
3.3
tpd @ Nom Voltage(Max)(ns)20.6
9.3
7.3
6.2
RoHSНе совместим
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Specialty Logic > Decoder/Encoder/Multiplexer
На английском языке: Datasheet Texas Instruments SN74LVC139APWLE
