Datasheet Texas Instruments THS1031IPW — Даташит
СерияTHS1031
МодельTHS1031IPW
10-разрядный АЦП, 30 MSPS, одноканальный, встроенный.
3-V to 5.5-V, 10-Bit, 30 MSPS CMOS Analog-to-Digital Converter datasheet
PDF, 728 Кб, Версия: E, Файл опубликован: 21 мар 2002
16 предложений от 15 поставщиков
Микросхема Преобразователь AD, 10Bit, 30MSPS ADC Single Ch., Integ. Pgmable Digital Clamp & Gain, Out of ange Indic., PowerDown 28-TSSOP -40℃...
THS1031IPW
1 004 ₽
THS1031IPW
1 439 ₽
T-electron
THS1031IPW
47 982 ₽
THS1031IPW
Pgmable Digital Clamp & Gain, индикатор выхода за пределы диапазона, PowerDown 28-TSSOP от -40 до 85
Pin28
Package TypePW
Industry STD TermTSSOP
МаркировкаTJ1031
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Рекомендуемая замена
ReplacementADS825E
Replacement CodeP
# Input Channels1
Analog Input BW(MHz)150
Approx. Price (US$)7.67 | 100u
АрхитектураPipeline
DNL(Max)(+/-LSB)1
ENOB(Bits)7.7
INL(Max)(+/-LSB)2
Input BufferNo
Input Range2V (p-p)
InterfaceParallel CMOS
Package GroupTSSOP
Package Size: mm2:W x L (PKG)28TSSOP: 62 mm2: 6.4 x 9.7(TSSOP)
Power Consumption(Typ)(mW)160
Reference ModeExt
Int
Resolution(Bits)10
SFDR(dB)52.4
SINAD(dB)56
SNR(dB)49.3
Sample Rate(Max)(MSPS)30
RoHSНе совместим
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200EVM: Low Cost Portable Power Supply
  • Using TI FIFOs to Interface High-Speed Data Converters With TI TMS320 DSPs
    PDF, 249 Кб, Файл опубликован: 8 июн 2001
    Most high-speed data converters cannot be connected directly to a digital signal processor (DSP). The required transfer rates would tie up most of the DSP's I/O bandwidth. A FIFO is an appropriate solution for this problem because it can buffer a large block of data, and the DSP can read data from the FIFO in a burst mode. This is much more efficient compared to single reads for every sampled valu
  • CDCE62005 as Clock Solution for High-Speed ADCs
    PDF, 805 Кб, Файл опубликован: 4 сен 2008
    TI has introduced a family of devices well-suited to meet the demands for high-speed ADC devices such as the ADS5527 which is capable of sampling up to 210 MSPS. To realize the full potential of these high-performance products it is imperative to provide a low phase noise clock source. The CDCE62005 clock synthesizer chip offers a real-world clocking solution to meet these stringent requirements
  • Smart Selection of ADC/DAC Enables Better Design of Software-Defined Radio
    PDF, 376 Кб, Файл опубликован: 28 апр 2009
    This application report explains different aspects of selecting analog-to-digital and digital-to-analog data converters for Software-Defined Radio (SDR) applications. It also explains how ADS61xx ADCs and the DAC5688 from Texas Instruments fit properly for SDR designs.
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Semiconductors > Data Converters > Analog to Digital Converter > High Speed ADC (>10MSPS)
На английском языке: Datasheet Texas Instruments THS1031IPW
