Datasheet Texas Instruments SN54ALS04BJ — Даташит
Серия | SN54ALS04B |
Модель | SN54ALS04BJ |
Шестигранные инверторы 14-CDIP от -55 до 125
Hex Inverters datasheet
PDF, 1.2 Мб, Версия: B, Файл опубликован: 1 дек 1994
Купить SN54ALS04BJ на РадиоЛоцман.Цены — от 424 до 5 911 ₽ 10 предложений от 10 поставщиков Inverter 6Element Bipolar 14Pin CDIP Tube | |||
SN54ALS04BJ Texas Instruments | 424 ₽ | ||
SN54ALS04BJ Texas Instruments | 534 ₽ | ||
SN54ALS04BJ Texas Instruments | 1 147 ₽ | ||
SN54ALS04BJ Texas Instruments | по запросу |
Pin | 14 |
Package Type | J |
Industry STD Term | CDIP |
JEDEC Code | R-GDIP-T |
Package QTY | 1 |
Carrier | TUBE |
Маркировка | SN54ALS04BJ |
Width (мм) | 6.67 |
Length (мм) | 19.56 |
Thickness (мм) | 4.57 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Bits | 6 |
Тип входа | TTL |
Тип выхода | TTL |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | ALS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
Voltage(Nom) | 5 В |
RoHS | See ti.com |
- Bus-Interface Devices With Output-Damping Resistors Or Reduced-Drive Outputs (Rev. A)PDF, 105 Кб, Версия: A, Файл опубликован: 1 авг 1997
The spectrum of bus-interface devices with damping resistors or balanced/light output drive currently offered by various logic vendors is confusing at best. Inconsistencies in naming conventions and methods used for implementation make it difficult to identify the best solution for a given application. This report attempts to clarify the issue by looking at several vendors? approaches and discussi - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN54ALS04B (10)
- Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Buffer Drivers
