Datasheet Texas Instruments UCC29412PWG4 — Даташит
Серия | UCC29412 |
Модель | UCC29412PWG4 |
Синхронный повышающий преобразователь малой мощности 8-TSSOP от -40 до 85
Datasheet
Voltage Regulators - Switching Regulators Low Power Synch Boost Converter | |||
UCC29412PWG4 | по запросу | ||
UCC29412PWG4 Texas Instruments | по запросу | ||
Pin | 8 |
Package Type | PW |
Industry STD Term | TSSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 4.4 |
Length (мм) | 3 |
Thickness (мм) | 1 |
Pitch (мм) | .65 |
Max Height (мм) | 1.2 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Basic Calculation of a Boost Converter's Power Stage (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 8 янв 2014
This application note gives the equations to calculate the power stage of a boost converter built with an IC with integrated switch and operating in continuous conduction mode. It is not intended to give details on the functionality of a boost converter (see Reference 1) or how to compensate a converter. See the references at the end of this document if more detail is needed.
Серия: UCC29412 (2)
- UCC29412PW UCC29412PWG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
