Datasheet Texas Instruments OPA379AIDCKTG4 — Даташит
Серия | OPA379 |
Модель | OPA379AIDCKTG4 |
1,8 В, 2,9 мкА, 90 кГц Операционный усилитель ввода-вывода Rail-to-Rail 5-SC70 от -40 до 125
1.8V, 2.9µA, 90kHz, Rail-to-Rail I/O Operational Amplifiers datasheet
PDF, 1.5 Мб, Версия: D, Файл опубликован: 8 янв 2007
![]() 17 предложений от 13 поставщиков Микросхема Операционный усилитель, 1.8V, 2.9uA, 90kHz ail-to- ail I/O Operational Amplifier 5-SC70 -40℃ to 125℃ | |||
OPA379AIDCKTG4 Texas Instruments | от 9.34 ₽ | ||
OPA379AIDCKTG4 Texas Instruments | 35 ₽ | ||
OPA379AIDCKTG4 Texas Instruments | 235 ₽ | ||
OPA379AIDCKTG4 Texas Instruments | по запросу |
Pin | 5 |
Package Type | DCK |
Industry STD Term | SOT-SC70 |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | B54 |
Width (мм) | 1.25 |
Length (мм) | 2 |
Thickness (мм) | .9 |
Pitch (мм) | .65 |
Max Height (мм) | 1.1 |
Mechanical Data | Скачать |
Additional Features | EMI Hardened |
Архитектура | CMOS |
CMRR(Min) | 90 дБ |
CMRR(Typ) | 100 дБ |
GBW(Typ) | 0.09 МГц |
Input Bias Current(Max) | 50 pA |
Iq per channel(Max) | 0.0055 мА |
Iq per channel(Typ) | 0.0029 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 2.7 uV/C |
Output Current(Typ) | 5 мА |
Package Group | SC70 |
Package Size: mm2:W x L | 5SC70: 4 mm2: 2.1 x 2(SC70) PKG |
Rail-to-Rail | In,Out |
Rating | Catalog |
Slew Rate(Typ) | 0.03 V/us |
Total Supply Voltage(Max) | 5.5 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 1.8 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 80 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 1.5 мВ |
- Supplying TPS61200 With a Single Solar Cell (Rev. B)PDF, 129 Кб, Версия: B, Файл опубликован: 6 сен 2011
This application report explains how to use the TPS61200 in combination with a single solar cell to charge a battery or storage device. A characteristic of solar cells is the internal resistance that can vary from less than 10 Ω up to more than 100 Ω. Therefore it is important to control the load placed on the solar cell to ensure a reliable start-up of the application. This report describes an a - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA379 (12)
- Semiconductors > Amplifiers > Operational Amplifiers (Op Amps) > Ultra-Low-Power Op Amps (<=10uA)
