Datasheet Texas Instruments OMAPL137BZKB4 — Даташит
СерияOMAP-L137
МодельOMAPL137BZKB4
C6000 DSP+ARM процессор 256-BGA от 0 до 90
OMAP-L137 Low-Power Applications Processor datasheet
PDF, 1.6 Мб, Версия: G, Файл опубликован: 17 июн 2014
7 предложений от 7 поставщиков
OMAPL137BZKB4
68 ₽
LifeElectronics
OMAPL137BZKB4
IC Home
OMAPL137BZKB4
OMAPL137BZKB4
Pin256256
Package TypeZKBZKB
Industry STD TermBGABGA
JEDEC CodeS-PBGA-NS-PBGA-N
МаркировкаOMAPL137BZKB4
Width (мм)1717
Length (мм)1717
Thickness (мм)1.361.36
Pitch (мм)11
Max Height (мм)2.052.05
Рекомендуемая замена
ReplacementOMAPL137CZKB4
Replacement CodeS
ARM CPU1 ARM9
ARM MHz (Max.)456
ApplicationsCommunications and Telecom
Consumer Electronics
Energy
Industrial
Medical
Approx. Price (US$)14.30 | 1ku
DRAMSDRAM
DSP1 C674x
DSP MHz (Max.)456
Display Options1
EMAC10/100
I2C2
On-Chip L2 Cache256 KB (DSP)
Operating SystemsDSP/BIOS
Operating Temperature Range(C)-40 to 105
0 to 70
Other On-Chip Memory128 KB
SPI2
UART(SCI)3
USB2
Video Port (Configurable)1
RoHSНе совместим
  • Evaluation Modules & Boards: TMDSOSKL137
    OMAP-L137/TMS320C6747 Floating Point Starter Kit
    XDS200 USB Debug Probe
  • OMAP-L137 Complementary Products
    PDF, 27 Кб, Файл опубликован: 23 сен 2009
    This article has been contributed to the TI DaVinciв„ў and OMAPв„ў Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L137_Complementary_Products .This Wiki article serves as a repository of complimentary devices t
  • OMAP-L137 Technical Brief (Rev. B)
    PDF, 170 Кб, Версия: B, Файл опубликован: 18 фев 2009
    OMAP-L13x are the latest OMAP Processors combining floating-point high-precision processing, networking and GUI capabilities with scalability, system intergration and low-power consumption.
  • OMAP-L137 Power Consumption Summary
    PDF, 19 Кб, Файл опубликован: 30 июн 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://processors.wiki.ti.com/index.php/OMAP-L137_Power_Consumption_Summary.This article discusses the power consumption of the Texas Instruments OMAP-L137. Powe
  • Powering the OMAP-L132/OMAP-L137/OMAP-L138 Processor with the TPS650061
    PDF, 695 Кб, Файл опубликован: 13 апр 2012
    TPS650061, OMAP-L132, OMAP-L137, OMAP-L138 Power Sequencing for OMAP-L132, L137, and L138 using the TPS650061
  • Power Solution using a Dual DCDC Converter and a LDO (Rev. A)
    PDF, 174 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • Using the OMAP-L1x7 Bootloader (Rev. G)
    PDF, 2.6 Мб, Версия: G, Файл опубликован: 1 июн 2012
    This application report describes various boot mechanisms supported by the OMAP-L1x7 bootloader read-only memory (ROM) image. Topics covered include the Application Image Script (AIS) boot process, an AISgen tool used to generate boot scripts, protocol for booting the device from an external master device, a UART Boot Host GUI for booting the device from a host PC, and any limitations, default set
  • TMS320C6747/45/43 & OMAP-L1x7 USB Downstream Host Compliance Testing
    PDF, 2.8 Мб, Файл опубликован: 12 мар 2009
    This appication report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • TMS320C6747/45/43 & OMAP-L1x7 USB Upstream Device Compliance Testing
    PDF, 510 Кб, Файл опубликован: 12 мар 2009
    This application report describes the TMS320C674x/OMAP-L1x electrical compliance of a high-speed (HS) universal serial bus (USB) operation conforming to the USB 2.0 specification. The on-the-go (OTG) controller supports the USB 2.0 device and host mode at high-speed (HS), full-speed (FS), and low-speed (LS).
  • OMAP-L137 TMS320C6747/6745/6743 Pin Multiplexing Utility (Rev. A)
    PDF, 39 Кб, Версия: A, Файл опубликован: 26 сен 2009
    The OMAP-L137, C6747/6745/6743 devices use a great deal of internal pin multiplexing to allow the most functionality in the smallest and lowest cost package. This software allows the pin multiplexing registers of the device to be calculated with ease, as well as showing what peripherals can be used together and what devices support the peripherals that are selected. This software is useful to anyo
  • Power Solution Using Discrete DC/DC Converters and LDOs (Rev. B)
    PDF, 299 Кб, Версия: B, Файл опубликован: 26 авг 2010
  • OMAP-L13x/AM1x Linux PSP Overview
    PDF, 20 Кб, Файл опубликован: 18 авг 2010
    This article has been contributed to the Texas Instrument's Embedded Processors Wiki site:http://processors.wiki.ti.com/index.php/Community_Linux_PSP_for_DA8x/OMAP-L1/AM1xThe Linux Platform Support Package (PSP) for Sitara AM1x and OMAP-L13x provides support for Linux kernel, U-Boot, UBL and
  • Canny Edge Detection Implementation on TMS320C64x/64x+ Using VLIB
    PDF, 97 Кб, Файл опубликован: 25 ноя 2009
    This application note contains instructions for implementing Canny Edge Detection algorithm using VLIB. The general ideas given here can also be applied for an application which calls a sequence of VLIB functions in a block-based manner.
  • Power Solution using LDO's (Rev. A)
    PDF, 125 Кб, Версия: A, Файл опубликован: 25 мар 2010
  • TMS320C674x/OMAP-L1x USB Compliance Checklist
    PDF, 89 Кб, Файл опубликован: 12 мар 2009
    This application report contains the USB checklist for the TMS320C674x/OMAP-L1x (C674x/OMAP-L1x). The C674x/OMAP-L1x has a compliant full-speed USB device port and does not support a low-speed USB device operation.
  • OMAP-L1x/C674x/AM1x SOC Architecture and Throughput Overview
    PDF, 19 Кб, Файл опубликован: 12 фев 2010
    This article has been contributed to the TI Developer Wiki. To see the most recently updated version or to contribute, visit this topic at:http://wiki.davincidsp.com/index.php/OMAP-L1x/C674x/AM1x_SOC_Architecture_and_Throughput_Overview. This collection of Wiki articles provide i
  • High-Speed Interface Layout Guidelines (Rev. G)
    PDF, 814 Кб, Версия: G, Файл опубликован: 27 июл 2017
    As modern bus interface frequencies scale higher, care must be taken in the printed circuit board (PCB) layout phase of a design to ensure a robust solution.
  • Semiconductors > Processors > Digital Signal Processors > C6000 DSP + ARM Processors > OMAP-L1x
На английском языке: Datasheet Texas Instruments OMAPL137BZKB4
