Datasheet Texas Instruments TPS62351DRCR — Даташит
Серия | TPS62351 |
Модель | TPS62351DRCR |
Понижающий преобразователь 1 А, 3 МГц с I2C для динамического масштабирования напряжения 10-VSON от -40 до 85
800-mA 3-MHz Synchronous Step-Down Converter With I2C(TM) Compatible Interface datasheet
PDF, 1.6 Мб, Версия: E, Файл опубликован: 15 апр 2008
![]() 11 предложений от 11 поставщиков Преобразователь DC/DC, Conv DC-DC 2.7V to 5.5V Step Down Single-Out 0.9V to 1.6875V 1A 10Pin VSON EP T/R | |||
TPS62351DRCR Texas Instruments | 28 ₽ | ||
TPS62351DRCR Texas Instruments | 136 ₽ | ||
TPS62351DRCR Texas Instruments | 463 ₽ | ||
TPS62351DRCR | по запросу |
Pin | 10 |
Package Type | DRC |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Package QTY | 3000 |
Carrier | LARGE T&R |
Маркировка | BNT |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Control Mode | Voltage Mode |
Duty Cycle(Max) | 80 % |
Iout(Max) | 0.8 A |
Iq(Typ) | 0.028 мА |
Package Group | VSON |
Rating | Catalog |
Regulated Outputs | 1 |
Special Features | Dynamic Voltage Scaling,Enable,Frequency Synchronization,Light Load Efficiency,Output Discharge,Synchronous Rectification |
Switching Frequency(Max) | 3350 kHz |
Switching Frequency(Min) | 2650 kHz |
Тип | Converter |
Vin(Max) | 5.5 В |
Vin(Min) | 2.7 В |
Vout(Max) | 1.6875 В |
Vout(Min) | 0.9 В |
- Evaluation Modules & Boards: TPS62351EVM-122
TPS62351EVM-122 Evaluation Module
- Powering OMAP3 With TPS6235x: Design-In GuidePDF, 296 Кб, Файл опубликован: 3 дек 2008
The OMAP35xx Applications Processors have a diverse set of power management features which potentially enable lower cost power solutions based on your application. This design-in guide describes a power solution based on the TPS6235x device. This guide can be used to evaluate this solution for your design or help you make decisions when designing in this solution. - Optimizing Transient Response of Internally Compensated DC-DC Converters (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 11 май 2015
- Five steps to a great PCB layout for a step-down converterPDF, 162 Кб, Файл опубликован: 29 янв 2015
- Understanding the Absolute Maximum Ratings of the SW Node (Rev. A)PDF, 755 Кб, Версия: A, Файл опубликован: 13 янв 2012
- Testing tips for applying external power to supply outputs without an input voltPDF, 110 Кб, Файл опубликован: 24 окт 2016
- Basic Calculation of a Buck Converter's Power Stage (Rev. B)PDF, 202 Кб, Версия: B, Файл опубликован: 17 авг 2015
- Extending the Soft Start Time Without a Soft Start Pin (Rev. B)PDF, 387 Кб, Версия: B, Файл опубликован: 15 июн 2017
- QFN and SON PCB Attachment (Rev. B)PDF, 821 Кб, Версия: B, Файл опубликован: 24 авг 2018
- IQ: What it is what it isn’t and how to use itPDF, 198 Кб, Файл опубликован: 17 июн 2011
- Performing Accurate PFM Mode Efficiency Measurements (Rev. A)PDF, 418 Кб, Версия: A, Файл опубликован: 11 дек 2018
Серия: TPS62351 (2)
- TPS62351DRCR TPS62351DRCRG4
- Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Down (Buck) > Buck Converter (Integrated Switch)
