Datasheet Texas Instruments TL499ACP — Даташит
СерияTL499A
МодельTL499ACP
Широкодиапазонный контроллер источника питания 8-PDIP от -20 до 85
TL499A Wide-Range Power-Supply Controllers datasheet
PDF, 838 Кб, Версия: H, Файл опубликован: 30 ноя 2015
41 предложений от 24 поставщиков
TL499ACPS
34 ₽
TL499ACP
59 ₽
TL499ACPS
113 ₽
TL499ACPS
Package TypeP
Industry STD TermPDIP
JEDEC CodeR-PDIP-T
Package QTY50
МаркировкаTL499ACP
Width (мм)6.35
Length (мм)9.81
Thickness (мм)3.9
Pitch (мм)2.54
Max Height (мм)5.08
Рабочий диапазон температурот -20 до 85 C
Package GroupPDIP
Regulated Outputs1
Switch Current Limit(Min)0.1 A
Switch Current Limit(Typ)0.5 A
ТипConverter
Vin(Max)10 В
Vin(Min)1.1 В
Vout(Max)30 В
Vout(Min)2.9 В
  • Designing Switching Voltage Regulators With the TL499A
    PDF, 497 Кб, Файл опубликован: 8 авг 2003
    In this application report, the TL499A wide-range power-supply controller is discussed in detail. A general overview of TL499A architecture presents the primary functions of the device and its features. An in-depth study of the device, used with several external components, showcases the versatility and limitations of the device and provides a thorough understanding of the criteria required to sel
  • Understanding Buck Power Stages In Switchmode Power Supplies
    PDF, 173 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the buck power stage only and does not cover control circuits. Detailed steady-state and small-signal analysis of the buck power stage operating in continuous
  • Understanding Boost Power Stages In Switchmode Power Supplies
    PDF, 149 Кб, Файл опубликован: 4 мар 1999
    A switching power supply consists of the power stage and the control circuit. The power stage performs the basic power conversion from the input voltage to the output voltage and includes switches and the output filter. This report addresses the boost power stage only and does not cover control circuits. The report includes detailed steady-stage and small-signal analysis of the boost power stage o
  • Understanding Buck-Boost Power Stages in Switchmode Power Supplies (Rev. A)
    PDF, 363 Кб, Версия: A, Файл опубликован: 28 май 2002
Серия: TL499A (3)
  • Semiconductors > Power Management > Non-isolated DC/DC Switching Regulator > Step-Up (Boost) > Boost Converter (Integrated Switch)
На английском языке: Datasheet Texas Instruments TL499ACP
