Datasheet Texas Instruments THS5661IDWR — Даташит
Серия | THS5661 |
Модель | THS5661IDWR |
12 бит, 125 MSPS, CommsDAC, диф. Масштабируемые токовые выходы от 2 мА до 20 мА 28-SOIC от -40 до 85
12-BIT, 100 MSPS, CommsDAC DIGITAL-TO-ANALOG CONVERTER | |||
THS5661IDWR Texas Instruments | по запросу | ||
Pin | 28 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Width (мм) | 7.5 |
Length (мм) | 17.9 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
RoHS | Не совместим |
- Wideband Complementary Current Output DAC Single-Ended InterfacePDF, 597 Кб, Файл опубликован: 21 июн 2005
High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA - Noise Analysis for High Speed Op Amps (Rev. A)PDF, 256 Кб, Версия: A, Файл опубликован: 17 янв 2005
Серия: THS5661 (4)
- THS5661IDW THS5661IDWR THS5661IPW THS5661IPWR
- Semiconductors > Data Converters > Digital to Analog Converter > Precision DAC (=<10MSPS)
