Datasheet Texas Instruments 5962-9455501MRA — Даташит
Серия | UC1875 |
Модель | 5962-9455501MRA |
Резонансный регулятор фазового сдвига 20-CDIP от -55 до 125
Phase Shift Resonant Controller datasheet
PDF, 5.7 Мб, Версия: C, Файл опубликован: 24 май 2007
Soft Sw PWM Cntrlr 4Out PH SHIFT RES 1MHz 20Pin CDIP Tube | |||
5962-9455501MRA Texas Instruments | 7 970 ₽ | ||
5962-9455501MRA | по запросу | ||
5962-9455501MRA Texas Instruments | по запросу | ||
UC1875J/883B 5962-9455501MRA (UC1875J/883B 5962-9455501MRA) | по запросу |
Pin | 20 | 20 | 20 |
Package Type | J | J | J |
Industry STD Term | CDIP | CDIP | CDIP |
JEDEC Code | R-GDIP-T | R-GDIP-T | R-GDIP-T |
Package QTY | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE |
Маркировка | UC1875J/883B | 5962-9455501MR | A |
Width (мм) | 6.92 | 6.92 | 6.92 |
Length (мм) | 24.2 | 24.2 | 24.2 |
Thickness (мм) | 4.57 | 4.57 | 4.57 |
Pitch (мм) | 2.54 | 2.54 | 2.54 |
Max Height (мм) | 5.08 | 5.08 | 5.08 |
Control Method | Current,Feedforward,Voltage |
Duty Cycle(Max) | 100 % |
Frequency(Max) | 1000 kHz |
Package Group | CDIP |
Package Size: mm2:W x L | See datasheet (CDIP) PKG |
Rating | Military |
Special Features | Error Amplifier,Soft Start,Soft Switching,Synchronization Pin |
Topology | Full-Bridge |
UVLO Thresholds On/Off | 10/7 В |
Vin(Max) | 20 В |
Vin(Min) | 9.25 В |
RoHS | See ti.com |
- Phase Shifted Full Bridge, Zero Voltage Transition Design Considerations (Rev. A)PDF, 393 Кб, Версия: A, Файл опубликован: 22 янв 2011
This Application Note will highlight the design considerations incurred in a high frequency power supply using the Phase Shifted Resonant PWM control technique. An overview of this switching technique including comparisons to existing fixed frequency non-resonant and variable frequency Zero Voltage Switching is included. Numerous design equations and associated voltage, current and timing waveform
Серия: UC1875 (6)
- 5962-9455501M3A 5962-9455501MRA UC1875J UC1875J883B UC1875L UC1875L883B
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
59629455501MRA, 5962 9455501MRA
