Datasheet Texas Instruments 8412801EA — Даташит
СерияSN54HC151
Модель8412801EA
Селекторы/мультиплексоры данных с 8 на 1 линию 16-CDIP от -55 до 125
SN54HC151, SN74HC151 datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 26 сен 2003
Multiplexer, HC/UH Series, 1-Func, 8 Line Input, 1 Line Output, Complementary Output, CMOS, CDIP16, CERAMIC, DIP-16
T-electron
8412801EA
879 ₽
8412801EA
Harris
893 ₽
8412801EA
1 147 ₽
8412801EA
Pin1616
Package TypeJJ
Industry STD TermCDIPCDIP
JEDEC CodeR-GDIP-TR-GDIP-T
Package QTY11
CarrierTUBETUBE
Маркировка8412801EASNJ54HC151J
Width (мм)6.926.92
Length (мм)19.5619.56
Thickness (мм)4.574.57
Pitch (мм)2.542.54
Max Height (мм)5.085.08
Количество каналов1
F @ Nom Voltage(Max)28 Mhz
ICC @ Nom Voltage(Max)0.08 мА
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyHC
VCC(Max)6 В
VCC(Min)2 В
Voltage(Nom)3.3,5 В
tpd @ Nom Voltage(Max)63 нс
RoHSSee ti.com
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
На английском языке: Datasheet Texas Instruments 8412801EA
