Datasheet Texas Instruments DAC5675MPHPEP — Даташит
СерияDAC5675-EP
МодельDAC5675MPHPEP
Усовершенствованный продукт 14-битный цифро-аналоговый преобразователь, скорость 400 МГц, 48-HTQFP от -55 до 125
DAC5675-EP datasheet
PDF, 1.1 Мб, Версия: A, Файл опубликован: 24 окт 2006
Микросхема Преобразователь DA, DAC 1CH Segment 14Bit 48Pin HTQFP EP Tray
DAC5675MPHPEP
4 398 ₽
Элитан
DAC5675MPHPEP
48 251 ₽
DAC5675MPHPEP
727GS
DAC5675MPHPEP
Pin48
Package TypePHP
Industry STD TermHTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierJEDEC TRAY (10+1)
МаркировкаDC5675MEP
Width (мм)7
Length (мм)7
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
АрхитектураCurrent Sink
DAC Channels1
DNL(Max)2 +/-LSB
Gain Error(Max)10 %FSR
INL(Max)4 +/-LSB
InterfaceParallel LVDS
Output Range Max.20 мА
Output Range Min.2 мА
Тип выходаCurrent
Package GroupHTQFP
Package Size: mm2:W x L48HTQFP: 81 mm2: 9 x 9(HTQFP) PKG
Power Consumption(Typ)820 mW
RatingHiRel Enhanced Product
Reference: TypeInt
Разрешение14 Bits
SFDR77 дБ
Sample / Update Rate400 MSPS
Время установления0.012 µs
  • Evaluation Modules & Boards: TSW2200EVM
    TSW2200 Low-Cost Portable Power Supply Evaluation Module
  • Phase Noise Performance and Jitter Cleaning Ability of CDCE72010
    PDF, 2.3 Мб, Файл опубликован: 2 июн 2008
    This application report presents phase noise data taken on the CDCE72010 jitter cleaner and synchronizer PLL device. The phase noise performance of the CDCE72010 depends on the phase noise of the reference clock VCXO clock and the CDCE72010 itself. This application report shows the phase noise performance at several of the most popular CDMA frequencies. This data helps the user to choose the rig
  • CDCE72010 as a Clocking Solution for High-Speed Analog-to-Digital Converters
    PDF, 424 Кб, Файл опубликован: 8 июн 2008
    Texas Instruments has recently introduced a family of devices suitable to meet the demands of high-speed high-IF sampling analog-to-digital converters (ADCs) such as the ADS5483 which is capable of sampling up to 135 MSPS. To realize the full potential of these high-performance devices the system must provide an extremely low phase noise clock source. The CDCE72010 clock synthesizer chip offers
  • Semiconductors > Space & High Reliability > Data Converter > Digital to Analog Converters
На английском языке: Datasheet Texas Instruments DAC5675MPHPEP
Публикации по теме
