Datasheet Texas Instruments OPA27GUG4 — Даташит
Серия | OPA27 |
Модель | OPA27GUG4 |
Прецизионные операционные усилители со сверхмалым шумом 8-SOIC от -40 до 85
Ultra-Low Noise, Precision Operational Amplifiers datasheet
PDF, 967 Кб, Версия: C, Файл опубликован: 29 авг 2005
![]() 9 предложений от 9 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS OPA27GUG4 Operational Amplifier, Single, 1 Amplifier, 8MHz, 1.9V/µs, ± 4V to ± 22V, SOIC, 8Pins | |||
OPA27GUG4 Texas Instruments | 86 ₽ | ||
OPA27GUG4 Texas Instruments | 163 ₽ | ||
OPA27GUG4 Texas Instruments | 209 ₽ | ||
OPA27GUG4 Texas Instruments | по запросу |
Pin | 8 | 8 |
Package Type | D | D |
Industry STD Term | SOIC | SOIC |
Package QTY | 75 | 75 |
Carrier | TUBE | TUBE |
Маркировка | OPA | 27U |
Width (мм) | 3.91 | 3.91 |
Length (мм) | 4.9 | 4.9 |
Thickness (мм) | 1.58 | 1.58 |
Pitch (мм) | 1.27 | 1.27 |
Max Height (мм) | 1.75 | 1.75 |
Additional Features | N/A |
Архитектура | Bipolar |
CMRR(Min) | 100 дБ |
CMRR(Typ) | 122 дБ |
GBW(Typ) | 8 МГц |
Input Bias Current(Max) | 8000 pA |
Iq per channel(Max) | 5.7 мА |
Iq per channel(Typ) | 3.3 мА |
Количество каналов | 1 |
Offset Drift(Typ) | 0.4 uV/C |
Output Current(Typ) | 25 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rail-to-Rail | Out |
Rating | Catalog |
Slew Rate(Typ) | 1.9 V/us |
Total Supply Voltage(Max) | 44 +5V=5, +/-5V=10 |
Total Supply Voltage(Min) | 8 +5V=5, +/-5V=10 |
Vn at 1kHz(Typ) | 3.2 нВ/rtГц |
Vos (Offset Voltage @ 25C)(Max) | 0.1 мВ |
- Operational Amplifier Macromodels: A ComparisonPDF, 59 Кб, Файл опубликован: 27 сен 2000
All major competitors in the operational amplifier markets are providing their customers Spice-based macromodels. These models give the designer a tool to do initial characterization and a limited amount of system troubleshooting. In the interest of faster simulation times and lower CPU memory requirements, macro topologies have been developed to simulate a majority of the op amp's performance cha - An Error Analysis of the ISO102 in a Small Signal Measuring ApplicationPDF, 29 Кб, Файл опубликован: 27 сен 2000
High accuracy measurements of low-level signals in the presence of high isolation mode voltages can be difficult due to the errors of the isolation amplifiers themselves. - Level Shifting Signals with Differential AmplifiersPDF, 23 Кб, Файл опубликован: 27 сен 2000
The INA105 is a unity gain differential amplifier consisting of a premium grade operational amplifier and an on-chip precision resistor network. The self-contained INA105 makes it ideal for many applications. One such application is precision level shifting. - Tuning in AmplifiersPDF, 44 Кб, Файл опубликован: 2 окт 2000
Have you ever had the experience of designing an analog gain block with an amplifier that is specified to be unity gain stable only to find that it is oscillating out of control in your circuit? Or have you ever replaced a stable voltage feedback amplifier with a current feedback amplifier to find that the current feedback amplifier immediately oscillates when placed in the amplifier socket? Oscil - Single-Supply Operation of Operational AmplifiersPDF, 77 Кб, Файл опубликован: 2 окт 2000
Operation of op amps from single supply voltages is useful when negative supply voltages are not available. Furthermore, certain applications using high voltage and high current op amps can derive important benefits from single supply operation. - Op Amp Performance AnalysisPDF, 76 Кб, Файл опубликован: 2 окт 2000
Серия: OPA27 (7)
- OPA27GP OPA27GPG4 OPA27GU OPA27GU/2K5 OPA27GU/2K5E4 OPA27GUE4 OPA27GUG4
