Datasheet Texas Instruments TMP275AIDR — Даташит
Серия | TMP275 |
Модель | TMP275AIDR |
В±0.5В°C Temperature Sensor with I2C/SMBus Interface in Industry Std LM75 Form Factor & Pinout 8-SOIC -40 to 125
TMP275 В±0.5В°C Temperature Sensor With I2C and SMBus Interface in Industry Standard LM75 Form Factor and Pinout datasheet
PDF, 1.1 Мб, Версия: E, Файл опубликован: 20 ноя 2015
Купить TMP275AIDR на РадиоЛоцман.Цены — от 24 до 368 ₽ 32 предложений от 13 поставщиков Сенсоры, Датчики Тепловые датчики — с аналоговым и цифровым выходом | |||
TMP275AIDR Texas Instruments | от 24 ₽ | ||
TMP275AIDR Texas Instruments | от 55 ₽ | ||
TMP275AIDR Texas Instruments | 122 ₽ | ||
TMP275AIDR Texas Instruments | от 368 ₽ |
Pin | 8 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 2500 |
Carrier | LARGE T&R |
Маркировка | TMP275 |
Width (мм) | 3.91 |
Length (мм) | 4.9 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Addresses | 8 |
Interface | I2C, SMBus, 2-Wire |
Iq(Typ) | 50 uA |
Local Sensor Accuracy(Max) | 0.5 +/- C |
Package Group | SOIC |
Package Size: mm2:W x L | 8SOIC: 29 mm2: 6 x 4.9(SOIC) PKG |
Rating | Catalog |
Special Features | Configurable Resolution,Programmable Alert,Fault Queue,One-Shot Conversion,Shutdown |
Supply Current(Max) | 85 uA |
Supply Current(Typ) | 50 uA |
Supply Voltage(Max) | 5.5 В |
Supply Voltage(Min) | 2.7 В |
Temp Resolution(Max) | 12 bits |
- Thermocouple Temperature Measurements Using Isolated Amplifiers (Rev. A)PDF, 145 Кб, Версия: A, Файл опубликован: 11 авг 2017
The most common thermocouple in use today is the Type K. A Type-K thermocouple is inexpensive accurate and works reliably in harsh environments. Type-K thermocouples can measure temperatures ranging from –200°C to +1250°C and have a Seebeck coefficient of S = 41 μV/K at room temperature. - Applying I2C-Compatible Temperature Sensors in Systems With Slow Clock Edges (Rev. A)PDF, 33 Кб, Версия: A, Файл опубликован: 6 май 2013
This Application Note describes a method of interfacing a given microcontroller with a Texas Instruments digital temperature sensor. - Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: TMP275 (8)
- Semiconductors > Sensing Products > Temperature Sensors > Local Digital Temperature Sensors
