Datasheet Texas Instruments SN74LVC00ADT — Даташит
Серия | SN74LVC00A |
Модель | SN74LVC00ADT |
Четверной логический элемент положительного NAND с 2 входами 14-SOIC от -40 до 125
SNx4LVC00A Quadruple 2-Input Positive-NAND Gates datasheet
PDF, 1.4 Мб, Версия: R, Файл опубликован: 3 фев 2016
![]() 29 предложений от 16 поставщиков Интегральные микросхемы Логические микросхемы - Затворы и Инверторы | |||
SN74LVC00ADT Texas Instruments | от 16 ₽ | ||
SN74LVC00ADT Texas Instruments | от 17 ₽ | ||
SN74LVC00ADT Texas Instruments | 29 ₽ | ||
SN74LVC00ADT | по запросу |
Pin | 14 |
Package Type | D |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 250 |
Carrier | SMALL T&R |
Маркировка | LVC00A |
Width (мм) | 3.91 |
Length (мм) | 8.65 |
Thickness (мм) | 1.58 |
Pitch (мм) | 1.27 |
Max Height (мм) | 1.75 |
Mechanical Data | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 150 Mhz |
ICC @ Nom Voltage(Max) | 0.04 мА |
Output Drive (IOL/IOH)(Max) | 24/-24 мА |
Package Group | SOIC |
Package Size: mm2:W x L | 14SOIC: 52 mm2: 6 x 8.65(SOIC) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max) | 3.6 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,2.7,3.3 В |
tpd @ Nom Voltage(Max) | 12.5,6.4,5.1,4.3 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly - Power-Up 3-State (PU3S) Circuits in TI Standard Logic DevicesPDF, 209 Кб, Файл опубликован: 10 май 2002
Серия: SN74LVC00A (22)
- SN74LVC00AD SN74LVC00ADBLE SN74LVC00ADBR SN74LVC00ADBRE4 SN74LVC00ADBRG4 SN74LVC00ADE4 SN74LVC00ADG4 SN74LVC00ADR SN74LVC00ADRE4 SN74LVC00ADRG4 SN74LVC00ADT SN74LVC00ANSR SN74LVC00ANSRG4 SN74LVC00APW SN74LVC00APWE4 SN74LVC00APWG4 SN74LVC00APWLE SN74LVC00APWR SN74LVC00APWRE4 SN74LVC00APWRG4 SN74LVC00APWT SN74LVC00ARGYR
- Semiconductors > Logic > Gate > NAND Gate
