Источники питания Keen Side
Datasheet Texas Instruments SN74LVCH245AZQNR — Даташит
СерияSN74LVCH245A
МодельSN74LVCH245AZQNR
Восьмеричный шинный трансивер с выходами с 3 состояниями, 20 BGA MICROSTAR JUNIOR от -40 до 85
SNx4LVCH245A Octal Bus Transceivers With 3-State Outputs datasheet
PDF, 1.7 Мб, Версия: P, Файл опубликован: 6 май 2014
Микросхема Логический контроллер, Octal Bus Transceiver With 3-State Outputs 20-BGA MICROSTAR JUNIOR -40℃ to 85℃
SN74LVCH245AZQNR
21 ₽
T-electron
SN74LVCH245AZQNR
22 ₽
SN74LVCH245AZQNR
55 ₽
SN74LVCH245AZQNR
Pin20
Package TypeZQN
Industry STD TermBGA MICROSTAR JUNIOR
JEDEC CodeR-PBGA-N
Package QTY1000
МаркировкаLCH245A
Width (мм)3
Length (мм)4
Thickness (мм).75
Max Height (мм)1
Bits8
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-24/24 мА
Package GroupBGA MICROSTAR JUNIOR
Package Size: mm2:W x L20BGA MICROSTAR JUNIOR: 8 mm2: 3 x 2.5(BGA MICROSTAR JUNIOR) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)12.7,8.3,7.3,6.3 нс
  • Bus-Hold Circuit
    PDF, 418 Кб, Файл опубликован: 5 фев 2001
    When designing systems that include CMOS devices, designers must pay special attention to the operating condition in which all of the bus drivers are in an inactive, high-impedance condition (3-state). Unless special measures are taken, this condition can lead to undefined levels and, thus, to a significant increase in the device?s power dissipation. In extreme cases, this leads to oscillation of
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments SN74LVCH245AZQNR
