Источники питания Keen Side
Datasheet Texas Instruments 74LVCR2245ADBQRG4 — Даташит
СерияSN74LVCR2245A
Модель74LVCR2245ADBQRG4
Восьмеричный шинный трансивер с выходами с 3 состояниями 20-SSOP от -40 до 125
SN74LVCR2245A Octal Bus Transceiver with 3-State Outputs datasheet
PDF, 1.5 Мб, Версия: N, Файл опубликован: 12 ноя 2014
Микросхема Логический контроллер, Transceiver, 74LVC245, 2V to 3.6V, QSOP-20
74LVCR2245ADBQRG4
23 ₽
T-electron
74LVCR2245ADBQRG4
29 ₽
74LVCR2245ADBQRG4
34 ₽
74LVCR2245ADBQRG4
Pin20
Package TypeDBQ
Industry STD TermSSOP
Package QTY2500
МаркировкаLVCR2245A
Width (мм)3.9
Length (мм)8.65
Thickness (мм)1.5
Pitch (мм).64
Max Height (мм)1.75
Bits8
F @ Nom Voltage(Max)100 Mhz
ICC @ Nom Voltage(Max)0.01 мА
Output Drive (IOL/IOH)(Max)-12/12 мА
Package GroupSSOP
Package Size: mm2:W x L20SSOP: 52 mm2: 6 x 8.65(SSOP) PKG
Schmitt TriggerNo
Technology FamilyLVC
VCC(Max)3.6 В
VCC(Min)1.65 В
Voltage(Nom)1.8,2.5,2.7,3.3 В
tpd @ Nom Voltage(Max)7.3,6.3 нс
  • 16-Bit Widebus Logic Families in 56-Ball 0.65-mm Pitch Very Thin Fine-Pitch BGA (Rev. B)
    PDF, 895 Кб, Версия: B, Файл опубликован: 22 май 2002
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • How to Select Little Logic (Rev. A)
    PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
    TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b
  • Migration From 3.3-V To 2.5-V Power Supplies For Logic Devices
    PDF, 115 Кб, Файл опубликован: 1 дек 1997
    This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn
  • Texas Instruments Little Logic Application Report
    PDF, 359 Кб, Файл опубликован: 1 ноя 2002
    Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond
  • Live Insertion
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Logic > Buffer/Driver/Transceiver > Standard Transceiver
На английском языке: Datasheet Texas Instruments 74LVCR2245ADBQRG4
