Datasheet Texas Instruments LM3646YFQR — Даташит
СерияLM3646
МодельLM3646YFQR
Светодиодный флэш-драйвер с синхронным усилением, 1,5 А, с двумя источниками тока верхнего плеча 20-DSBGA от -40 до 85
LM3646 1.5-A Synchronous Boost Converter With Dual High-Side Current Sources and I2C-Compatible Interface datasheet
PDF, 1.9 Мб, Версия: A, Файл опубликован: 28 ноя 2014
Драйвер LED , Conv DC-DC 2.7V to 5.5V Step Up Single-Out -0.3V to 6V 1.5A 20Pin DSBGA T/R
LM3646YFQR
16 ₽
LM3646YFQR
62 ₽
LM3646YFQR
ЗУМ-СМД
LM3646YFQR
Pin20
Package TypeYFQ
Industry STD TermDSBGA
JEDEC CodeR-XBGA-N
Package QTY3000
Маркировка3646
Thickness (мм).42
Pitch (мм).4
Max Height (мм).675
Iout(Max)1.5 A
Iq(Typ)1.0 мА
LED2
Package GroupDSBGA
Special FeaturesI2C Control,Input/Output Isolation,LED Thermal Monitor,Load Disconnect During Shutdown,Over Current Protection,OVP,Synchronous Rectification
Vin(Max)5.5 В
Vin(Min)2.7 В
  • Evaluation Modules & Boards: LM3646EVM
    Evaluation Module for LM3646 Dual LED Flash Driver with I2C Compatible Interface
  • LED Flash-Protection Features
    PDF, 33 Кб, Файл опубликован: 23 авг 2017
    Modern LED camera flash drivers are feature-rich and power dense. Capable of delivering over 2 A ofcurrent to dual LEDs in packages as small as 1.69 mm Г— 1.31 mm, flash LED drivers require built-in safetyand protection features to maintain long-term device and system health. Devices such as the LM3643,LM3644, LM3648, LM3646, LM3642, LM36010, and LM36011 all provide many specific protection
Серия: LM3646 (1)
  • LM3646YFQR
  • Semiconductors > Power Management > LED Driver > Strobe & Flash LED Driver
На английском языке: Datasheet Texas Instruments LM3646YFQR
