Источники питания Keen Side
Datasheet Texas Instruments THS3111DGN — Даташит
СерияTHS3111
МодельTHS3111DGN
Одиночный малошумящий высоковольтный усилитель с токовой обратной связью 8-MSOP-PowerPAD от -40 до 85
Low-Noise, High-Voltage, Current-Feedback Op Amplifiers datasheet
PDF, 1.3 Мб, Версия: E, Файл опубликован: 12 окт 2009
THS3111DGN
THS3111DGN
Package TypeDGN
Industry STD TermHVSSOP
JEDEC CodeS-PDSO-G
Width (мм)3
Length (мм)3
Thickness (мм)1.02
Max Height (мм)1.1
2nd Harmonic(dBc)52
3rd Harmonic(dBc)48
@ MHz10
Acl, min spec gain(V/V)1
Additional FeaturesN/A
Approx. Price (US$)2.72 | 100u
АрхитектураBipolar
Current FB
BW @ Acl(MHz)100
CMRR(Min)(dB)62
CMRR(Typ)(dB)68
GBW(Typ)(MHz)100
Input Bias Current(Max)(pA)4000000
Iq per channel(Max)(mA)6.5
Iq per channel(Typ)(mA)4.8
Number of Channels(#)1
Offset Drift(Typ)(uV/C)10
Operating Temperature Range(C)-40 to 85
0 to 70
Output Current(Typ)(mA)260
Package GroupMSOP-PowerPAD
Package Size: mm2:W x L (PKG)8MSOP-PowerPAD: 15 mm2: 4.9 x 3(MSOP-PowerPAD)
Rail-to-RailNo
Slew Rate(Typ)(V/us)900
Total Supply Voltage(Max)(+5V=5, +/-5V=10)30
Total Supply Voltage(Min)(+5V=5, +/-5V=10)10
Vn at Flatband(Typ)(nV/rtHz)3
Vos (Offset Voltage @ 25C)(Max)(mV)10
RoHSНе совместим
  • Evaluation Modules & Boards: THS3111EVM
    THS3111 Evaluation Module
  • Evaluation Modules & Boards: THS3121EVM
    THS3121 Evaluation Module
  • Evaluation Modules & Boards: THS3120EVM
    THS3120 Evaluation Module
  • Evaluation Modules & Boards: THS3110EVM
    THS3110 Evaluation Module
  • Active filters using current-feedback amplifiers
    PDF, 227 Кб, Файл опубликован: 25 фев 2005
  • Expanding the usability of current-feedback amplifiers
    PDF, 215 Кб, Файл опубликован: 28 фев 2005
  • Wideband Complementary Current Output DAC Single-Ended Interface
    PDF, 597 Кб, Файл опубликован: 21 июн 2005
    High-speed digital-to-analog converters (DACs) most often use a transformer-coupled output stage. In applications where this configuration is not practical, a single op ampdifferential to single-ended stage has often been used. This application note steps through the exact design equations required to achieve gain matching from each output as well as a matched input impedance to each of the DA
На английском языке: Datasheet Texas Instruments THS3111DGN
