Клеммные колодки Keen Side
Datasheet Texas Instruments VCA2614Y/250 — Даташит
СерияVCA2614
МодельVCA2614Y/250
Двойной усилитель с переменным коэффициентом усиления и малошумящим предусилителем 32-TQFP от -40 до 85
VCA2614: Dual, Variable Gain Amplifier with Input Buffer datasheet
PDF, 919 Кб, Версия: D, Файл опубликован: 28 фев 2003
VCA2614Y/250
1 178 ₽
T-electron
VCA2614Y/250
1 360 ₽
VCA2614Y/250
1 500 ₽
ЭИК
VCA2614Y/250
3 384 ₽
Pin32
Package TypePBS
Industry STD TermTQFP
JEDEC CodeS-PQFP-G
Package QTY250
CarrierSMALL T&R
Маркировка2614Y
Width (мм)5
Length (мм)5
Thickness (мм)1
Pitch (мм).5
Max Height (мм)1.2
Acl, min spec gain1.5 V/V
BW @ Acl40 МГц
Max Gain45 дБ
Количество каналов2
PGA/VGAVGA
Package GroupTQFP
Package Size: mm2:W x L32TQFP: 49 mm2: 7 x 7(TQFP) PKG
Slew Rate(Typ)300 V/us
Vs(Max)5.25 В
Vs(Min)4.75 В
  • Evaluation Modules & Boards: VCA2619EVM
    VCA2619 Evaluation Module
  • Evaluation Modules & Boards: VCA2614EVM
    VCA2614 Evaluation Module
  • Dual-Channel VCAs: Methods for Powering Down One Channel
    PDF, 102 Кб, Файл опубликован: 11 июн 2004
    Texas Instruments offers several product groups of highly-integrated voltage-controlled amplifiers (VCAs) including the VCA2611/12/13/16 and the VCA2614/18/19. Both the VCA2611 and the VCA2614 families feature two channels, either of which can be powered while powering down the other. This application note outlines two possible approaches to this question and describes the steps needed to assure t
  • AB-170: Ultrasound Processor Supplementary Material
    PDF, 752 Кб, Файл опубликован: 25 янв 2001
    An ultrasound system employs a multichannel phased array of acoustic elements to form an image. Previous implementation of this function has used bipolar technology. 0.5u CMOS technology has the advantage of lowering the cost and increasing functionality compared to using bipolar technology.
Серия: VCA2614 (1)
  • VCA2614Y/250
  • Semiconductors > Amplifiers > Programmable & Variable Gain Amplifiers (PGA/VGA)
На английском языке: Datasheet Texas Instruments VCA2614Y/250
