Datasheet Texas Instruments CD4066BF3AS2534 — Даташит
СерияCD4066B
МодельCD4066BF3AS2534
КМОП четырехсторонний двусторонний переключатель 14-CDIP
CD4066B CMOS Quad Bilateral Switch datasheet
PDF, 1.4 Мб, Версия: G, Файл опубликован: 13 июн 2017
Pin14
Package TypeJ
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Width (мм)6.67
Length (мм)19.56
Thickness (мм)4.57
Pitch (мм)2.54
Max Height (мм)5.08
Additional FeaturesLow Crosstalk
Low Power
Bandwidth(Max)(MHz)40
Configuration1:1 SPST
Crosstalk(dB)Yes
Number of Channels(#)4
Operating Temperature Range(C)-55 to 125
Package GroupPDIP
SO
SOIC
TSSOP
Package Size: mm2:W x L (PKG)See datasheet (CDIP)
See datasheet (PDIP)
RatingMilitary
Ron(Max)(Ohms)240
Ron(Typ)(Ohms)125
Technology FamilyCD4000
VCC(Max)(V)18
VCC(Min)(V)3
RoHSНе совместим
  • Selecting the Right Texas Instruments Signal Switch
    PDF, 769 Кб, Файл опубликован: 7 сен 2001
    Texas Instruments offers a wide variety of electronic switches (digital analog bilateral bilateral analog) in a variety of families including CBT CBTLV HC LV and LVC. Depending on the application the right solution may be an analog switch that passes digital signals or vice versa. This application report summarizes the various switching technologies and provides considerations for choosi
  • Semiconductors > Switches and Multiplexers > Signal Switches > Analog Switch
На английском языке: Datasheet Texas Instruments CD4066BF3AS2534
