Datasheet Texas Instruments SN74LVC02ADBLE — Даташит
Серия | SN74LVC02A |
Модель | SN74LVC02ADBLE |
Четверной 2-входовой элемент положительного ИЛИ-НЕ 14-SSOP от -40 до 125
SN54LVC02A, SN74LVC02A datasheet
PDF, 1.3 Мб, Версия: Q, Файл опубликован: 26 июл 2005
Логические элементы Quad 2-Input | |||
SN74LVC02ADBLE Texas Instruments | по запросу | ||
Pin | 14 |
Package Type | DB |
Industry STD Term | SSOP |
JEDEC Code | R-PDSO-G |
Width (мм) | 5.3 |
Length (мм) | 6.2 |
Thickness (мм) | 1.95 |
Pitch (мм) | .65 |
Max Height (мм) | 2 |
Mechanical Data | Скачать |
Approx. Price (US$) | 0.08 | 1ku |
Bits(#) | 4 |
F @ Nom Voltage(Max)(Mhz) | 70 |
ICC @ Nom Voltage(Max)(mA) | 0.04 |
Тип входа | TTL |
Operating Temperature Range(C) | -40 to 125 |
Output Drive (IOL/IOH)(Max)(mA) | 24/-24 |
Тип выхода | TTL |
Package Group | SSOP |
Package Size: mm2:W x L (PKG) | 14TSSOP: 32 mm2: 6.4 x 5(TSSOP) |
Rating | Catalog |
Schmitt Trigger | No |
Technology Family | LVC |
VCC(Max)(V) | 3.6 |
VCC(Min)(V) | 1.5 |
Voltage(Nom)(V) | 1.8 2.5 2.7 3.3 |
tpd @ Nom Voltage(Max)(ns) | 8.9 7.4 5.4 4.4 |
RoHS | Не совместим |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC02A (18)
- Semiconductors > Logic > Gate > NOR Gate
