Datasheet Texas Instruments 5962-8868701LA — Даташит
СерияSN54AS652
Модель5962-8868701LA
Восьмеричные шинные трансиверы и регистры с выходами с 3 состояниями 24-CDIP от -55 до 125
Octal Bus Transceivers And Registers With 3-State Outputs datasheet
PDF, 793 Кб, Версия: G, Файл опубликован: 7 дек 2000
Bus XCVR Single 8-CH 3-ST 24-Pin CDIP Tube
5962-8868701LA
4 248 ₽
5962-8868701LA
4 977 ₽
HXD Co.
5962-8868701LA
TradeElectronics
5962-8868701LA
Littelfuse
Pin24
Package TypeJT
Industry STD TermCDIP
JEDEC CodeR-GDIP-T
Package QTY1
Width (мм)6.92
Length (мм)32
Thickness (мм)4.7
Pitch (мм)2.54
Max Height (мм)5.08
Bits8
Package GroupCDIP
RatingMilitary
Schmitt TriggerNo
Technology FamilyAS
VCC(Max)5.5 В
VCC(Min)4.5 В
RoHSSee ti.com
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Introduction to Logic
  • Live Insertion
Серия: SN54AS652 (3)
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceiver
59628868701LA, 5962 8868701LA
На английском языке: Datasheet Texas Instruments 5962-8868701LA
