Datasheet Texas Instruments SN74LVC1G14DRY2 — Даташит
СерияSN74LVC1G14
МодельSN74LVC1G14DRY2
Одиночный инвертор Шмитта 6-SON от -40 до 125
SN74LVC1G14 Single Schmitt-Trigger Inverter datasheet
PDF, 1.5 Мб, Версия: X, Файл опубликован: 25 авг 2017
6 предложений от 5 поставщиков
IC INVERT SCHMITT 1CH 1-INP 6SON / Inverter IC 1 Channel Schmitt Trigger 6-SON (1.45x1)
727GS
SN74LVC1G14DRY2
от 126 ₽
SN74LVC1G14DRY2
IC Home
SN74LVC1G14DRY2
SN74LVC1G14DRY2
Pin6
Package TypeDRY
Industry STD TermUSON
JEDEC CodeR-PDSO-N
МаркировкаCF
Width (мм)1
Length (мм)1.45
Thickness (мм).5
Pitch (мм).5
Max Height (мм).6
3-State OutputNo
Approx. Price (US$)0.06 | 1ku
Bits(#)1
F @ Nom Voltage(Max)(Mhz)150
Gate TypeSCHMITT TRIGGER INVERTER
ICC @ Nom Voltage(Max)(mA)0.01
LogicInverting
Operating Temperature Range(C)-40 to 125
-40 to 85
Output Drive (IOL/IOH)(Max)(mA)32/-32
Package GroupSON
Package Size: mm2:W x L (PKG)See datasheet (SON)
Schmitt TriggerYes
Special FeaturesIoff
down translation to Vcc
low power
Schmitt-trigger
Sub-FamilyInverting Buffer/Driver
Technology FamilyLVC
VCC(Max)(V)5.5
VCC(Min)(V)1.65
Voltage(Nom)(V)1.8
2.5
3.3
5
tpd @ Nom Voltage(Max)(ns)11
6.5
5.5
5
RoHSНе совместим
  • Evaluation Modules & Boards: DLPLCR6500EVM
    DLPВ® LightCrafterв„ў 6500 Evaluation Module
  • Evaluation Modules & Boards: DLPLCR9000EVM
    DLPВ® LightCrafterв„ў 9000 Evaluation Module
  • Understanding Schmitt Triggers
    PDF, 80 Кб, Файл опубликован: 21 сен 2011
  • LVC Characterization Information
    PDF, 114 Кб, Файл опубликован: 1 дек 1996
    This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices.
  • Use of the CMOS Unbuffered Inverter in Oscillator Circuits
    PDF, 796 Кб, Файл опубликован: 6 ноя 2003
    CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74LVC1G14DRY2
