Datasheet Texas Instruments SN74CBT3383CDW — Даташит
Серия | SN74CBT3383C |
Модель | SN74CBT3383CDW |
10-битные переключатели шины на полевых транзисторах с защитой от понижения напряжения -2 В 24-SOIC от -40 до 85
![]() 21 предложений от 11 поставщиков Микросхема Логический чип, 10Bit FET Bus-Exchange Switches with -2V Undershoot Protection 24-SOIC -40℃ to 85℃ | |||
SN74CBT3383CDW Texas Instruments | 34 ₽ | ||
SN74CBT3383CDW Texas Instruments | 66 ₽ | ||
SN74CBT3383CDW Texas Instruments | 80 ₽ | ||
SN74CBT3383CDW Texas Instruments | от 81 ₽ |
Pin | 24 |
Package Type | DW |
Industry STD Term | SOIC |
JEDEC Code | R-PDSO-G |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | CBT3383C |
Width (мм) | 7.5 |
Length (мм) | 15.4 |
Thickness (мм) | 2.35 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.65 |
Mechanical Data | Скачать |
Additional Features | Powered off protection,-2V undershoot protection |
Полоса частот | 200 МГц |
Configuration | crosspoint/exchange |
ESD Charged Device Model | 1 kV |
ESD HBM | 2 kV |
Input/Ouput Voltage(Max) | 5.5 В |
Input/Output Continuous Current(Max) | 128 мА |
Input/Output OFF-state Capacitance(Typ) | 8 пФ |
Input/Output ON-state Capacitance(Typ) | 18.5 пФ |
Количество каналов | 10 |
OFF-state leakage current(Max) | 10 мкА |
Package Group | SOIC |
Package Size: mm2:W x L | 24SOIC: 160 mm2: 10.3 x 15.5(SOIC) PKG |
Rating | Catalog |
Ron(Max) | 12 Ohms |
Ron(Typ) | 3 Ohms |
Supply Current(Max) | 3 uA |
Supply Range | 5.5 Max |
VIH(Min) | 2 В |
VIL(Max) | 0.8 В |
Vdd(Max) | 5.5 В |
Vdd(Min) | 4 В |
Vss(Max) | N/A В |
Vss(Min) | N/A В |
- CBT-C, CB3T, and CB3Q Signal-Switch FamiliesPDF, 584 Кб, Файл опубликован: 4 фев 2003
Signal switch devices are widely used in applications requiring bus isolation, multiplexing, demultiplexing, and voltage translation. Compared to other logic and linear product alternatives, signal switches are the fastest and least power consuming. Texas Instruments (TI) CBT-C, CB3Q, and CB3T signal-switch families have low on-state resistance, negligible power consumption, and better undershoot - VOLTAGE LEVEL TRANSLATION (SL) - FamilyPDF, 111 Кб, Файл опубликован: 21 сен 2011
- Bus FET Switch Solutions for Live Insertion ApplicationsPDF, 300 Кб, Файл опубликован: 7 фев 2003
Серия: SN74CBT3383C (6)
- SN74CBT3383CDBQR SN74CBT3383CDGVR SN74CBT3383CDW SN74CBT3383CDWR SN74CBT3383CPW SN74CBT3383CPWR
- Semiconductors > Switches and Multiplexers > Analog Switches/Muxes
