Datasheet Texas Instruments SN74LVC1G240DSFR — Даташит
Серия | SN74LVC1G240 |
Модель | SN74LVC1G240DSFR |
Один инвертирующий буфер/драйвер с выходами с 3 состояниями 6-SON от -40 до 125
Single Buffer/Driver With 3-State Output, SN74LVC1G240 datasheet
PDF, 1.3 Мб, Версия: L, Файл опубликован: 12 дек 2013
![]() 19 предложений от 9 поставщиков Микросхема Логический чип, Single Inverting Buffer/Driver With 3-State Outputs 6-SON -40℃ to 125℃ | |||
SN74LVC1G240DSFR Texas Instruments | 5.51 ₽ | ||
SN74LVC1G240DSFR Texas Instruments | 11 ₽ | ||
SN74LVC1G240DSFR Texas Instruments | 13 ₽ | ||
SN74LVC1G240DSFR Texas Instruments | 45 ₽ |
Pin | 6 |
Package Type | DSF |
Industry STD Term | X2SON |
JEDEC Code | S-PDSO-N |
Package QTY | 5000 |
Carrier | LARGE T&R |
Маркировка | CK |
Width (мм) | 1 |
Length (мм) | 1 |
Thickness (мм) | .35 |
Pitch (мм) | .35 |
Max Height (мм) | .4 |
Mechanical Data | Скачать |
3-State Output | Yes |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | BUFFER |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | Inverting |
Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power,3-state |
Sub-Family | Inverting Buffer/Driver |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 6.9,4.6,3.7,3.4 нс |
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1G240 (13)
- Semiconductors > Logic > Little Logic
