Datasheet Texas Instruments BUF634F — Даташит
СерияBUF634
МодельBUF634F
Высокоскоростной буфер 250 мА 5-DDPAK/TO-263
BUF634 250-mA High-Speed Buffer datasheet
PDF, 1.2 Мб, Версия: A, Файл опубликован: 25 ноя 2015
36 предложений от 22 поставщиков
BUF634F
68 ₽
BUF634F/500E3
363 ₽
ЗУМ-СМД
BUF634F/500
BUF634F/500
Pin5
Package TypeKTT
Industry STD TermTO-263
JEDEC CodeR-PSFM-G
МаркировкаBUF634F
Width (мм)8.42
Length (мм)10.16
Thickness (мм)4.58
Pitch (мм)1.7
Max Height (мм)4.83
Рекомендуемая замена
ReplacementBUF634FKTTT
Replacement CodeS
Approx. Price (US$)3.50 | 1ku
Diff Gain(%)0.4
Diff Phase(deg)0.1
Number of Channels(#)1
Operating Temperature Range(C)-40 to 125
Output Current(Typ)(mA)250
Package GroupDDPAK/TO-263
See datasheet (TO-220)
Vs(Max)(V)36
Vs(Min)(V)4.5
RoHSНе совместим
  • Add Current Limit to the BUF634
    PDF, 63 Кб, Файл опубликован: 27 сен 2000
    Modern buffer amplifiers, such as the BUF634, are often used with op amps to drive high-current demand loads such as cables or eletro-mechanical devices. BUF634 features internal overload protection to prevent its destruction under fault conditions. Internal current limit protects circuitry and wirebonds from excessive current. Internal over-temp shut down protects the device from excessive temper
  • Combining an Amplifier with the BUF634
    PDF, 72 Кб, Файл опубликован: 2 окт 2000
    The following application note descibes a combination using an op amp with the high-speed buffer BUF634 located in its feedback loop. Depending upon the op amp selected, large signals with output currents of over 500mA into the MHz range can be attained.
  • Power Amplifier Stress and Power Handling Limitations
    PDF, 55 Кб, Файл опубликован: 27 сен 2000
    To achieve reliable power amplifier designs you must consider the stress on the amplifier compared to its power handling limitations. Power handling limits are specified by the Safe Operating Area (SOA) curves of the power amp. Stress on the amplifier depends on amplifier load and signal conditions which can be evaluated with straightforward techniques.
  • Semiconductors > Amplifiers > Special Function Amplifiers > Video Amplifiers
На английском языке: Datasheet Texas Instruments BUF634F
