Datasheet Texas Instruments SN74LVC1GU04DRY2 — Даташит
Серия | SN74LVC1GU04 |
Модель | SN74LVC1GU04DRY2 |
Один инверторный вентиль 6-SON от -40 до 125
SN74LVC1GU04 Single Inverter Gate datasheet
PDF, 1.4 Мб, Версия: W, Файл опубликован: 5 янв 2016
![]() 19 предложений от 9 поставщиков Inverter Schmitt Trigger 1-Element CMOS 6-Pin SON T/R | |||
SN74LVC1GU04DRY2 Texas Instruments | 7.55 ₽ | ||
SN74LVC1GU04DRY2 Texas Instruments | 8.75 ₽ | ||
SN74LVC1GU04DRY2 Texas Instruments | 9.52 ₽ | ||
SN74LVC1GU04DRY2 Texas Instruments | 38 ₽ |
Pin | 6 |
Package Type | DRY |
Industry STD Term | USON |
JEDEC Code | R-PDSO-N |
Package QTY | 5000 |
Carrier | LARGE T&R |
Маркировка | CD |
Width (мм) | 1 |
Length (мм) | 1.45 |
Thickness (мм) | .5 |
Pitch (мм) | .5 |
Max Height (мм) | .6 |
Mechanical Data | Скачать |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 150 Mhz |
Gate Type | INVERTER BUFFER |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | Inverting |
Рабочий диапазон температур | от -40 до 125,-40 до 85 C |
Output Drive (IOL/IOH)(Max) | 32/-32 мА |
Package Group | SON |
Package Size: mm2:W x L | See datasheet (SON) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Ioff,down translation to Vcc,low power,Unbuffered output |
Sub-Family | Inverting Buffer/Driver |
Technology Family | LVC |
VCC(Max) | 5.5 В |
VCC(Min) | 1.65 В |
Voltage(Nom) | 1.8,2.5,3.3,5 В |
tpd @ Nom Voltage(Max) | 5.5,4.5,4.2,3.5 нс |
- Designing and Manufacturing with TI's X2SON PackagesPDF, 134 Кб, Файл опубликован: 23 авг 2017
- Understanding Schmitt TriggersPDF, 80 Кб, Файл опубликован: 21 сен 2011
- LVC Characterization InformationPDF, 114 Кб, Файл опубликован: 1 дек 1996
This document provides characterization information about low-voltage logic (LVL) that operates from a 3.3-V power supply. It addresses the issues of interfacing to 5-V logic ac performance power considerations input and output characteristics and signal integrity for this family of devices. - Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly
Серия: SN74LVC1GU04 (19)
- 74LVC1GU04DBVRE4 74LVC1GU04DBVRG4 74LVC1GU04DBVTG4 74LVC1GU04DCKRE4 74LVC1GU04DCKRG4 74LVC1GU04DCKTE4 74LVC1GU04DCKTG4 74LVC1GU04DRLRG4 SN74LVC1GU04DBVR SN74LVC1GU04DBVT SN74LVC1GU04DCKR SN74LVC1GU04DCKT SN74LVC1GU04DRLR SN74LVC1GU04DRY2 SN74LVC1GU04DRYR SN74LVC1GU04DSF2 SN74LVC1GU04DSFR SN74LVC1GU04YZPR SN74LVC1GU04YZVR
- Semiconductors > Logic > Little Logic
