Datasheet Texas Instruments PCF8574ANE4 — Даташит
Серия | PCF8574A |
Модель | PCF8574ANE4 |
Удаленный 8-битный расширитель ввода-вывода для шины I2C 16-PDIP от -40 до 85
PCF8574A Remote 8-Bit I/O Expander for I2C Bus datasheet
PDF, 1.3 Мб, Версия: F, Файл опубликован: 16 ноя 2015
![]() 14 предложений от 11 поставщиков Чип интерфейса, I2C GPIO Expander 100kHz 6V 16Pin PDIP Tube | |||
PCF8574ANE4 | от 194 ₽ | ||
PCF8574ANE4 Texas Instruments | от 408 ₽ | ||
PCF8574ANE4 Texas Instruments | от 446 ₽ | ||
PCF8574ANE4 Texas Instruments | по запросу |
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | PCF8574AN |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
I2C Address | 0111 xxx |
Max Frequency | 100 kHz |
Number of I/Os | 8 |
Package Group | PDIP |
Rating | Catalog |
VCC(Max) | 6 В |
VCC(Min) | 2.5 В |
Voltage Nodes | 5,3.3 В |
fSCLK(Max) | 0.1 МГц |
Бессвинцовая технология (Pb Free) | Да |
- Improving System Interrupt Management Using the PCF8574 and PCF8574A I/O ExpandePDF, 216 Кб, Файл опубликован: 27 июл 2001
In today?s complex, embedded, computing and data-communication systems, interrupts areused extensively to service peripheral devices. However, because of the pin-numberlimitation on packages, most microprocessors have only one or two interrupt lines.Consequently, several devices usually are connected to the same interrupt line. Thedrawback to this configuration is that the overhead process - Programming Fun Lights With TI's TCA6507PDF, 109 Кб, Файл опубликован: 30 ноя 2007
- Choosing the Correct I2C Device for New DesignsPDF, 87 Кб, Файл опубликован: 7 сен 2016
The I2C bus is a very popular and powerful bus used for communication between a single (or multiple)master and a single (or multiple) slave device. In many applications there is a potential need for moreslave devices on the bus, isolation between similar addressed slaves, or a need for more I/Os. Theseneeds can be solved with an I2C buffer, switch, and I/O expander.The application note h - Maximum Clock Frequency of I2C Bus Using RepeatersPDF, 116 Кб, Файл опубликован: 15 май 2015
TCA9617 Maximum Allowed Frequency on I2C Bus Using Repeaters - I2C Bus Pull-Up Resistor CalculationPDF, 157 Кб, Файл опубликован: 13 фев 2015
- Understanding the I2C BusPDF, 124 Кб, Файл опубликован: 30 июн 2015
Серия: PCF8574A (18)
- Semiconductors > Interface > I2C > I2C General Purpose I/O (GPIO)
