Клеммные колодки Keen Side
Datasheet Texas Instruments 5962-8873001DA — Даташит
СерияSN54AS1032A
Модель5962-8873001DA
Четверные буферы/драйверы с 2 входами с положительным ИЛИ 14-CFP от -55 до 125
Quadruple 2-Input Positive-O Buffers/Drivers 14-CFP -55 to 125
HXD Co.
5962-8873001DA
Pin14
Package TypeW
Industry STD TermCFP
JEDEC CodeR-GDFP-F
Width (мм)5.97
Length (мм)9.21
Thickness (мм)1.59
Max Height (мм)2.03
RoHSНе совместим
  • Advanced Schottky Load Management
    PDF, 277 Кб, Файл опубликован: 1 фев 1997
    Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme
  • Live Insertion
  • Shelf-Life Evaluation of Lead-Free Component Finishes
    PDF, 1.3 Мб, Файл опубликован: 24 май 2004
    The integrated circuit (IC) industry is converting to lead (Pb)-free termination finishes for leadframe-based packages. IC component users need to know the maximum length of time that components can be stored prior to being soldered. This study predicts shelf life of the primary Pb-free finishes being proposed by the industry. Components were exposed to a controlled environment, with known aging a
Серия: SN54AS1032A (5)
  • Semiconductors > Space & High Reliability > Logic Products > Gate Products
59628873001DA, 5962 8873001DA
На английском языке: Datasheet Texas Instruments 5962-8873001DA
