Datasheet Texas Instruments V62/04763-02XE — Даташит
СерияSN74ALVCH16245-EP
МодельV62/04763-02XE
Усовершенствованный 16-битный шинный приемопередатчик с выходами с 3 состояниями 48-SSOP от -55 до 125
SN74ALVCH16245-EP datasheet
PDF, 286 Кб, Версия: A, Файл опубликован: 8 мар 2006
5 предложений от 5 поставщиков
Микросхема Амортизатор, Bus XCVR Dual 16CH 3-ST 48Pin SSOP T/R
V62/04763-02XE
288 ₽
V62/04763-02XE
308 ₽
V62/04763-02XE
МосЧип
V62/04763-02XE
Pin48
Package TypeDL
Industry STD TermSSOP
Package QTY1000
МаркировкаALCH16245M
Width (мм)7.49
Length (мм)15.88
Thickness (мм)2.59
Pitch (мм).635
Max Height (мм)2.79
Bits16
Рабочий диапазон температурот -40 до 85,-55 до 125 C
Package GroupSSOP
Package Size: mm2:W x L48SSOP: 164 mm2: 10.35 x 15.88(SSOP) PKG
RatingHiRel Enhanced Product
Schmitt TriggerNo
Technology FamilyALVC
VCC(Max)3.6 В
VCC(Min)1.65 В
  • Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)
    PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
    In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families
  • TI SN74ALVC16835 Component Specification Analysis for PC100
    PDF, 43 Кб, Файл опубликован: 3 авг 1998
    The PC100 standard establishes design parameters for the PC SDRAM DIMM that is designed to operate at 100 MHz. The 168-pin, 8-byte, registered SDRAM DIMM is a JEDEC-defined device (JC-42.5-96-146A). Some of the defined signal paths include data signals, address signals, and control signals. This application report discusses the SN74ALVC16835 18-bit universal bus driver that is available from T
  • Logic Solutions for PC-100 SDRAM Registered DIMMs (Rev. A)
    PDF, 96 Кб, Версия: A, Файл опубликован: 13 май 1998
    Design of high-performance personal computer (PC) systems that are capable of meeting the needs imposed by modern operating systems and software includes the use of large banks of SDRAMs on DIMMs (see Figure 1).To meet the demands of stable functionality over the broad spectrum of operating environments, meet system timing needs, and to support data integrity, the loads presented by the large
  • Semiconductors > Space & High Reliability > Logic Products > Buffers/Drivers/Transceivers > Transceivers
V62/0476302XE, V62/04763 02XE
На английском языке: Datasheet Texas Instruments V62/04763-02XE
Публикации по теме
