Datasheet Texas Instruments SNJ54AS1000AFK — Даташит
Серия | SN54AS1000A |
Модель | SNJ54AS1000AFK |
Четверные буферы/драйверы положительного NAND с 2 входами 20-LCCC от -55 до 125
Quadruple 2-Input Positive-NAND Buffers/Drivers datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 1 янв 1995
![]() 10 предложений от 7 поставщиков Микросхема Логический чип, NAND Gate 4Element 2IN Bipolar 20Pin CLLCC Tube | |||
SNJ54AS1000AFK Texas Instruments | 2 019 ₽ | ||
SNJ54AS1000AFK Texas Instruments | 2 565 ₽ | ||
SNJ54AS1000AFK Texas Instruments | 11 255 ₽ | ||
SNJ54AS1000AFK Texas Instruments | по запросу |
Pin | 20 | 20 | 20 | 20 |
Package Type | FK | FK | FK | FK |
Industry STD Term | LCCC | LCCC | LCCC | LCCC |
JEDEC Code | S-CQCC-N | S-CQCC-N | S-CQCC-N | S-CQCC-N |
Package QTY | 1 | 1 | 1 | 1 |
Carrier | TUBE | TUBE | TUBE | TUBE |
Маркировка | 5962- | SNJ54AS | 1000AFK | 9162701M2A |
Width (мм) | 8.89 | 8.89 | 8.89 | 8.89 |
Length (мм) | 8.89 | 8.89 | 8.89 | 8.89 |
Thickness (мм) | 1.83 | 1.83 | 1.83 | 1.83 |
Pitch (мм) | 1.27 | 1.27 | 1.27 | 1.27 |
Max Height (мм) | 2.03 | 2.03 | 2.03 | 2.03 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
Bits | 4 |
F @ Nom Voltage(Max) | 35 Mhz |
ICC @ Nom Voltage(Max) | 0.019 мА |
Тип входа | TTL |
Output Drive (IOL/IOH)(Max) | 48/-48 мА |
Тип выхода | TTL |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Schmitt Trigger | No |
Technology Family | AS |
VCC(Max) | 5.5 В |
VCC(Min) | 4.5 В |
tpd @ Nom Voltage(Max) | 4 нс |
RoHS | See ti.com |
- Advanced Schottky Load ManagementPDF, 277 Кб, Файл опубликован: 1 фев 1997
Designers of high-speed systems that include advanced Schottky (AS) devices must consider the operating environment in their work. They must be aware of the individual device characteristics and their interaction with other devices. This document provides a detailed discussion of the waveform characteristics equivalent circuit models transmission line fanout and termination for AS load manageme - Advanced Schottky (ALS and AS) Logic FamiliesPDF, 1.9 Мб, Файл опубликован: 1 авг 1995
Серия: SN54AS1000A (4)
- 5962-9162701M2A 5962-9162701MCA SNJ54AS1000AFK SNJ54AS1000AJ
- Semiconductors > Space & High Reliability > Logic Products > Gate Products
