Datasheet Texas Instruments DRV8884PWPR — Даташит
СерияDRV8884
МодельDRV8884PWPR
Драйвер шагового двигателя 1,0 А с микрошагом 1/16 и встроенным датчиком тока (управление STEP/DIR) 24-HTSSOP от -40 до 125
DRV8884 1.0-A Stepper Motor Driver With Integrated Current Sense datasheet
PDF, 1.6 Мб, Версия: B, Файл опубликован: 21 апр 2016
28 предложений от 13 поставщиков
Драйвер электродвигателя, Motor / Motion / Ignition Controllers & Drivers 1A Stepper Motor Driver With 1/16 Microstepping and Integrated Current Sensing...
727GS
DRV8884PWPR
от 96 ₽
DRV8884PWPR
от 113 ₽
T-electron
DRV8884PWPR
130 ₽
DRV8884PWPR
от 336 ₽
Pin24
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаDRV8884
Width (мм)4.4
Length (мм)7.8
Thickness (мм)1
Max Height (мм)1.2
Additional FeaturesIntegrated Current Sensing
Control I/FSTEP/DIR
Micro-Stepping Levels16
Number of Full Bridges2
Package Size: mm2:W x L24HTSSOP: 50 mm2: 6.4 x 7.8(HTSSOP) PKG
Peak Output Current1 A
RDS(ON) (HS + LS)1400 mOhms
RMS Output Current0.7 A
Vs(Max)37 В
Vs(Min)8 В
  • Evaluation Modules & Boards: DRV8884EVM
    DRV8884 1.0A Stepper Motor Driver with Integrated Sense Resistor Evaluation Module
  • Full-Scale Current Adjustment Using a Digital-to-Analog Converter (DAC)
    PDF, 1.6 Мб, Файл опубликован: 10 мар 2017
    The ability to dynamically control current in an inductive load system is very important for stepper motor designs where different levels of torque control are desired. This adjustment feature can also be used to improve system efficiency by reducing the motor current in low-load situations, achieving a longer battery life.This application report is provided as a supplement t
Серия: DRV8884 (2)
  • Semiconductors > Motor Drivers > Stepper Drivers > Stepper Drivers with FETs
На английском языке: Datasheet Texas Instruments DRV8884PWPR
