Datasheet Texas Instruments TPS71256DRCRG4 — Даташит
Серия | TPS71256 |
Модель | TPS71256DRCRG4 |
Двойной выход 250 мА, сверхнизкий уровень шума, высокий PSRR, линейный стабилизатор с малым падением напряжения 10-VSON от -40 до 125
Datasheet
Купить TPS71256DRCRG4 на РадиоЛоцман.Цены — от 80 до 130 ₽ 12 предложений от 9 поставщиков new in stock for immediate delivery | |||
TPS71256DRCRG4 Texas Instruments | 80 ₽ | ||
TPS71256DRCRG4 Texas Instruments | от 85 ₽ | ||
TPS71256DRCRG4 Texas Instruments | по запросу | ||
Pin | 10 |
Package Type | DRC |
Industry STD Term | VSON |
JEDEC Code | S-PDSO-N |
Width (мм) | 3 |
Length (мм) | 3 |
Thickness (мм) | .9 |
Pitch (мм) | .5 |
Max Height (мм) | 1 |
Mechanical Data | Скачать |
Accuracy(%) | 3 |
Additional Features | Enable Overcurrent Protection Thermal Shutdown |
Approx. Price (US$) | 0.95 | 1ku |
Fixed Output Options(V) | 2.8 |
Iout(Max)(A) | 0.25 |
Iout2(A) | 0.25 |
Iq(Typ)(mA) | 0.3 |
Noise(uVrms) | 32 |
Operating Temperature Range(C) | -40 to 125 |
Output Capacitor Type | Ceramic |
Output Options | Fixed Output |
PSRR @ 100KHz(dB) | 37 |
Package Group | VSON |
Package Size: mm2:W x L (PKG) | 10VSON: 9 mm2: 3 x 3(VSON) |
Rating | Catalog |
Regulated Outputs(#) | 2 |
Vdo(Typ)(mV) | 125 |
Vin(Max)(V) | 5.5 |
Vin(Min)(V) | 2.7 |
Vout(Max)(V) | 2.8 |
Vout(Min)(V) | 2.8 |
Vout2(Max)(V) | 2.8 |
Vout2(Min)(V) | 2.8 |
RoHS | Не совместим |
- Evaluation Modules & Boards: TPS712XXEVM-050
TPS712xx Evaluation Module
- Using Thermal Calculation Tools for Analog ComponentsPDF, 1.1 Мб, Файл опубликован: 2 сен 2010
This document provides general guidance on the use of toolsand calculations for thermal estimates of component operating temperatures for analog devices. Of particularfocus are components with direct thermal paths to the PCB which is common for components which need a low thermal resistance to manage the dissipated power. This document provides practical considerations for estimation of o - LDO PSRR Measurement Simplified (Rev. A)PDF, 131 Кб, Версия: A, Файл опубликован: 9 авг 2017
This applicationreportexplainsdifferentmethodsof measuringthe PowerSupplyRejectionRatio(PSRR)of a Low-Dropout(LDO)regulatorand includesthe prosand consof thesemeasuringmethods - LDO Noise Demystified (Rev. A)PDF, 785 Кб, Версия: A, Файл опубликован: 9 авг 2017
Серия: TPS71256 (2)
- TPS71256DRCR TPS71256DRCRG4
- Semiconductors > Power Management > Linear Regulator (LDO) > Multi-Channel LDO
