Datasheet Texas Instruments SN74AHC1GU04DBVT — Даташит
Серия | SN74AHC1GU04 |
Модель | SN74AHC1GU04DBVT |
Одиночный инвертор 5-SOT-23 от -40 до 125
SN74AHC1GU04 Single Inverter Gate datasheet
PDF, 1.0 Мб, Версия: S, Файл опубликован: 24 окт 2016
![]() 29 предложений от 16 поставщиков Интегральные микросхемы Логические микросхемы - Затворы и Инверторы | |||
SN74AHC1GU04DBVT Texas Instruments | от 11 ₽ | ||
SN74AHC1GU04DBVT Texas Instruments | 18 ₽ | ||
SN74AHC1GU04DBVT Texas Instruments | от 70 ₽ | ||
SN74AHC1GU04DBVT Texas Instruments | от 147 ₽ |
Pin | 5 | 5 | 5 | 5 |
Package Type | DBV | DBV | DBV | DBV |
Industry STD Term | SOT-23 | SOT-23 | SOT-23 | SOT-23 |
JEDEC Code | R-PDSO-G | R-PDSO-G | R-PDSO-G | R-PDSO-G |
Package QTY | 250 | 250 | 250 | 250 |
Carrier | SMALL T&R | SMALL T&R | SMALL T&R | SMALL T&R |
Маркировка | AU4L | AU4G | AU4S | AU43 |
Width (мм) | 1.6 | 1.6 | 1.6 | 1.6 |
Length (мм) | 2.9 | 2.9 | 2.9 | 2.9 |
Thickness (мм) | 1.2 | 1.2 | 1.2 | 1.2 |
Pitch (мм) | .95 | .95 | .95 | .95 |
Max Height (мм) | 1.45 | 1.45 | 1.45 | 1.45 |
Mechanical Data | Скачать | Скачать | Скачать | Скачать |
3-State Output | No |
Bits | 1 |
F @ Nom Voltage(Max) | 75 Mhz |
Gate Type | INVERTER BUFFER |
ICC @ Nom Voltage(Max) | 0.01 мА |
Logic | Inverting |
Output Drive (IOL/IOH)(Max) | 8/-8 мА |
Package Group | SOT-23 |
Package Size: mm2:W x L | 5SOT-23: 8 mm2: 2.8 x 2.9(SOT-23) PKG |
Rating | Catalog |
Schmitt Trigger | No |
Special Features | Down translation to Vcc,low power,Unbuffered output |
Sub-Family | Inverting Buffer/Driver |
Technology Family | AHC |
VCC(Max) | 5.5 В |
VCC(Min) | 2 В |
Voltage(Nom) | 3.3,5 В |
tpd @ Nom Voltage(Max) | 10.6,7 нс |
- Use of the CMOS Unbuffered Inverter in Oscillator CircuitsPDF, 796 Кб, Файл опубликован: 6 ноя 2003
CMOS devices have a high input impedance high gain and high bandwidth. These characteristics are similar to ideal amplifier characteristics and hence a CMOS buffer or inverter can be used in an oscillator circuit in conjunction with other passive components. Now CMOS oscillator circuits are widely used in high-speed applications because they are economical easy to use and take significantly - Benefits & Issues of Migrating 5-V and 3.3-V Logic to Lower-Voltage Supplies (Rev. A)PDF, 154 Кб, Версия: A, Файл опубликован: 8 сен 1999
In the last few years the trend toward reducing supply voltage (VCC) has continued as reflected in an additional specification of 2.5-V VCC for the AVC ALVT ALVC LVC LV and the CBTLV families.In this application report the different logic levels at VCC of 5 V 3.3 V 2.5 V and 1.8 V are compared. Within the report the possibilities for migration from 5-V logic and 3.3-V logic families - How to Select Little Logic (Rev. A)PDF, 1.1 Мб, Версия: A, Файл опубликован: 26 июл 2016
TI Little Logic devices are logic-gate devices assembled in a small single- dual- or triple- gate package. Little Logic devices are widely used in portable equipment such as mobile phones MP3 players and notebook computers. Little Logic devices also are used in desktop computers and telecommunications. Little Logic gates are common components for easy PC board routing schematic design and b - Migration From 3.3-V To 2.5-V Power Supplies For Logic DevicesPDF, 115 Кб, Файл опубликован: 1 дек 1997
This application report explores the possibilities for migrating to 3.3-V and 2.5-V power supplies and discusses the implications.Customers are successfully using a wide range of low-voltage 3.3-V logic devices. These devices are within Texas Instruments (TI) advanced low-voltage CMOS (ALVC) crossbar technology (CBT) crossbar technology with integrated diode (CBTD) low-voltage crossbar techn - Texas Instruments Little Logic Application ReportPDF, 359 Кб, Файл опубликован: 1 ноя 2002
Portable and consumer electronic systems? needs present greater challenges today than ever before. Engineers strive to design smaller faster lower-cost systems to meet the market demand. Consequently the semiconductor industry faces a growing need to increase operating speed minimize power consumption and reduce packaging size. Texas Instruments manufactures a variety of Little Logic semicond - Advanced High-Speed CMOS (AHC) Logic Family (Rev. C)PDF, 102 Кб, Версия: C, Файл опубликован: 2 дек 2002
The Texas Instruments (TI) advanced high-speed CMOS (AHC) logic family provides a natural migration for high-speed CMOS (HCMOS) users who need more speed for low-power and low-drive applications. Unlike many other advanced logic families AHC does not have the drawbacks that come with higher speed e.g. higher signal noise and power consumption. The AHC logic family consists of gates medium-sca
Серия: SN74AHC1GU04 (10)
- Semiconductors > Logic > Little Logic
