Datasheet Texas Instruments SN74AUC1G02YZPR — Даташит
СерияSN74AUC1G02
МодельSN74AUC1G02YZPR
Одиночный вентиль положительного ИЛИ-НЕ с 2 входами 5-DSBGA от -40 до 85
Single 2-Input Positive-NOR Gate datasheet
PDF, 1.0 Мб, Версия: P, Файл опубликован: 15 мар 2007
29 предложений от 12 поставщиков
Интегральные микросхемы Логические микросхемы - Затворы и Инверторы
SN74AUC1G02YZPR
12 ₽
LIXINC Electronics
SN74AUC1G02YZPR
от 12 ₽
T-electron
SN74AUC1G02YZPR
17 ₽
Allelco
SN74AUC1G02YZPR
Pin555
Package TypeYZPYZPYZP
Industry STD TermDSBGADSBGADSBGA
JEDEC CodeR-XBGA-NR-XBGA-NR-XBGA-N
Package QTY300030003000
CarrierLARGE T&RLARGE T&RLARGE T&R
МаркировкаUBNUB7UB
Width (мм)1.251.251.25
Length (мм)1.751.751.75
Thickness (мм).31.31.31
Pitch (мм).5.5.5
Max Height (мм).5.5.5
3-State OutputNo
Bits1
F @ Nom Voltage(Max)250 Mhz
Gate TypeNOR
ICC @ Nom Voltage(Max)0.01 мА
LogicTrue
Output Drive (IOL/IOH)(Max)9/-9 мА
Package GroupDSBGA
Schmitt TriggerNo
Special FeaturesIOFF,low power consumption,low tpd
Sub-FamilyNOR Gate
Technology FamilyAUC
VCC(Max)2.7 В
VCC(Min)0.8 В
Voltage(Nom)0.8,1.2,1.5,1.8,2.5 В
tpd @ Nom Voltage(Max)4.6,3.2,2.2,1.9,1.7 нс
  • Application of the Texas Instruments AUC Sub-1-V Little Logic Devices (Rev. A)
    PDF, 449 Кб, Версия: A, Файл опубликован: 19 сен 2002
    Power consumption and speed are always concerns in electronic system logic design. Texas Instruments (TI) announces the industry?s first sub-1-V logic family that provides significant benefits to portable consumer electronics by operating at low power and high speed, while maintaining overall system signal integrity. TI?s next-generation logic family is the advanced ultra-low-voltage CMOS (AUC) fa
  • Designing With TI Ultra-Low-Voltage CMOS (AUC) Octals and Widebus Devices
    PDF, 374 Кб, Файл опубликован: 21 мар 2003
    System designers are continuously seeking ways to improve signal integrity, increase speed, and reduce power consumption in personal computers, telecommunication equipment, and other electronic systems. The Texas Instruments (TI) next-generation Advanced Ultra-low-voltage CMOS (AUC) octals and Widebus(TM) devices are designed to achieve these goals. These devices are designed for a 0.8-V to 2.7-V
  • Semiconductors > Logic > Little Logic
На английском языке: Datasheet Texas Instruments SN74AUC1G02YZPR
