Клеммные колодки Keen Side
Datasheet Texas Instruments TPS54010PWPRG4 — Даташит
СерияTPS54010
МодельTPS54010PWPRG4
Входное напряжение от 3 В до 4 В, синхронный понижающий преобразователь 14 А, 28-HTSSOP от -40 до 85
2.2 -4 -V, 14A Output Synchronous Buck PWM Switcher w/Integrated FETs datasheet
PDF, 1.1 Мб, Версия: B, Файл опубликован: 8 июн 2005
12 предложений от 10 поставщиков
Conv DC-DC 2.2V to 4V Step Down Single-Out 0.9V to 2.5V 14A 28Pin HTSSOP EP T/R
LIXINC Electronics
TPS54010PWPRG4
от 110 ₽
TPS54010PWPRG4
383 ₽
TPS54010PWPRG4
430 ₽
МосЧип
TPS54010PWPRG4
Pin28
Package TypePWP
Industry STD TermHTSSOP
Package QTY2000
МаркировкаTPS54010
Width (мм)4.4
Length (мм)9.7
Thickness (мм)1
Max Height (мм)1.2
Control ModeVoltage Mode
Duty Cycle(Max)90 %
Iout(Max)14 A
Iq(Typ)13 мА
Package GroupHTSSOP
Regulated Outputs1
Special FeaturesEnable,Frequency Synchronization,Power Good,Synchronous Rectification
Switching Frequency(Max)700 kHz
Switching Frequency(Min)280 kHz
ТипConverter
Vin(Max)4 В
Vin(Min)2.2 В
Vout(Max)2.5 В
Vout(Min)0.9 В
  • Evaluation Modules & Boards: TPS54010EVM-067
    14-A, 2.2-4.0 Vin DC/DC Converter with Adjustable Output Voltage Evaluation Module
  • Dual Output Power Supply Sequencing for High Performance Processors
    PDF, 6.0 Мб, Файл опубликован: 17 июл 2002
    Dual voltage power supply architectures are becoming commonplace in high performance microprocessor and digital signal processor (DSP) systems. To save power and increase processing speeds, processor cores have smaller geometry cells and require lower supply voltages than the system bus voltages. Power management in these systems requires special attention. Yesterday's power management ICs and app
  • Thermal Performance of SWIFT(TM) DC/DC Converters in the 28-Pin HTSSOP Package
    PDF, 267 Кб, Файл опубликован: 4 фев 2005
    The thermal management of printed-circuit boards is complex, but must be well understood to achieve optimum performance and reliability. SWIFT(TM) dc/dc converters in the 28-pin HTSSOP package rely on an exposed lead frame die pad [PowerPAD(TM)] on the bottom of the package to provide an extremely low thermal resistance from junction to case. The thermal performance of the 6-, 9-, and 14-A SWIFT d
  • Using Low Voltage SWIFT DC/DC Converters with Ceramic Capacitors
    PDF, 490 Кб, Файл опубликован: 8 янв 2003
    This application note investigates an adequate phase margin for stable operation of SWIFTв„ў regulators with the ceramic capacitors at worst-case tolerances of regulator and external parts. TI also shows how the bandwidth and gain of feedback loop impact on load-current transient-response characteristics. Measurements and analysis have shown that the voltage-mode control SWIFTв„ў regulat
Серия: TPS54010 (4)
На английском языке: Datasheet Texas Instruments TPS54010PWPRG4
