Datasheet Texas Instruments UCC3817N — Даташит
Серия | UCC3817 |
Модель | UCC3817N |
Предварительный регулятор коэффициента мощности BiCMOS 16-PDIP от 0 до 70
UCC2817, UCC2818, UCC3817 and UCC3818 BiCMOS Power Factor Pregulator datasheet
PDF, 1.4 Мб, Версия: K, Файл опубликован: 1 окт 2016
Купить UCC3817N на РадиоЛоцман.Цены — от 24 до 1 970 ₽ 33 предложений от 17 поставщиков Интегральные микросхемы Микросхемы управления электропитанием - Коррекция коэффициента мощности | |||
UCC3817N Texas Instruments | от 24 ₽ | ||
UCC3817N Texas Instruments | 136 ₽ | ||
UCC3817N Texas Instruments | 191 ₽ | ||
UCC3817N-W Texas Instruments | по запросу |
Pin | 16 |
Package Type | N |
Industry STD Term | PDIP |
JEDEC Code | R-PDIP-T |
Package QTY | 25 |
Carrier | TUBE |
Маркировка | UCC3817N |
Width (мм) | 6.35 |
Length (мм) | 19.3 |
Thickness (мм) | 3.9 |
Pitch (мм) | 2.54 |
Max Height (мм) | 5.08 |
Mechanical Data | Скачать |
Control Method | CCM |
Device Type | Single-phase PFC |
Operating Supply Current | 4 мА |
Operating Supply(Max) | 18 В |
Рабочий диапазон температур | от 0 до 70 C |
Package Group | PDIP |
Package Size: mm2:W x L | See datasheet (PDIP) PKG |
Peak Output Sink Current Gate Drive | 1.2 A |
Peak Output Source Current Gate Drive | -1.2 A |
Practical Operating Frequency(Max) | 0.25 МГц |
Rating | Catalog |
Special Features | < 150W Applications,> 750W Applications,Average Current Mode,Enable,OVP |
Startup Current | 0.15 мА |
UVLO Thresholds On/Off | 16/10 В |
- Evaluation Modules & Boards: UCC3817EVM
UCC3817EVM BiCMOS Power Factor Preregulator EVM
- PFC Family Differences UCC3817A/18A/19A and UCC3817/18/19PDF, 32 Кб, Файл опубликован: 18 авг 2003
The UCC3817A/18A/19A family of PFC controllers (UCC3817A family) is pin for pin compatible with the UCC3817/18/19 family of devices (UCC3817 family). The output stage of UCC3817A family has been updated to allow use of a smaller external gate drive resistor values. For some power supply designs where an adequately high enough gate drive resistor can not be used, the UCC3817A family offers a more r - UCC3817 Current Sense Transformer EvaluationPDF, 49 Кб, Файл опубликован: 13 фев 2004
- Synchronizing a PFC Controller from a Down Stream Controller Gate DrivePDF, 103 Кб, Файл опубликован: 3 ноя 2000
Due to pending line harmonic requirements at higher power levels, power factor correction (PFC) is required in some ac-to-dc off-line power converter applications. This type of power converter can be designed with two cascaded power stages similar to the configuration in Figure 1. The first stage is a boost converter that converts the ac voltage to dc voltage with PFC. The output voltage of the bo - AC Requirements for Power Factor Correction CircuitsPDF, 29 Кб, Файл опубликован: 28 мар 2002
This technical brief identifies the recommended range of IAC for each of the devices within the UCC3854 family of PFC controllers. - Startup Current transient of the Leading Edge Triggered PFC ControllersPDF, 43 Кб, Файл опубликован: 30 июн 2004
- Avoiding Audible Noise at Light Loads When Using Leading Edge Triggered PFC Con (Rev. C)PDF, 57 Кб, Версия: C, Файл опубликован: 13 апр 2011
This application note applies to the TI average current mode, leading edge modulation PFC controllers. See Applicable Device Table for part numbers. - DN-66 UC3854A/B and UC3855A/B Provide Power Limiting with Sinusoidal Input (Rev. A)PDF, 80 Кб, Версия: A, Файл опубликован: 6 ноя 2001
- Accurate PWM Duty Cycle ClampPDF, 58 Кб, Файл опубликован: 25 янв 2002
Power supply applications using current sense transformers require a duty cycle clamp on the pulse width modulator (PWM) to ensure transformer reset. Not all PWMs come with a duty cycle clamp presenting a problem for the power supply designer. This application note shows how to implement a duty cycle clamp by using a simple delay circuit.
Серия: UCC3817 (9)
- Semiconductors > Power Management > Offline and Isolated DC/DC Controllers and Converters > Power Factor Correction
