Datasheet Texas Instruments BQ2000PWG4 — Даташит
СерияBQ2000
МодельBQ2000PWG4
Импульсное многохимическое зарядное устройство для аккумуляторов с оконечной нагрузкой для определения пикового напряжения 8-TSSOP от -20 до 70
Programmable MultiChemistry Fast-Charge Management IC datasheet
PDF, 1.3 Мб, Версия: D, Файл опубликован: 7 дек 2009
Микросхема Чип управления батареи, Fast Charge Management Li-Ion/NiCD/NiMH Packs 2000mA 8Pin TSSOP Tube
BQ2000PWG4
133 ₽
T-electron
BQ2000PWG4
180 ₽
BQ2000PWG4
399 ₽
BQ2000PWG4
Package TypePW
Industry STD TermTSSOP
Package QTY150
МаркировкаBQ200
Width (мм)4.4
Length (мм)3
Thickness (мм)1
Max Height (мм)1.2
Absolute Vin (safety rating)(Max)(7 В
Battery Charge Voltage(Max)20 В
Cell ChemistryLi-Ion/Li-Polymer,NiCd,NiMH
Charge Current(Max)2 A
Control InterfaceStandalone (RC-Settable)
Control TopologySwitch-Mode Buck
Number of Series Cells1,2,3,4
Operating Vin(Max)6 В
Operating Vin(Min)4 В
Package GroupTSSOP
Package Size: mm2:W x L8TSSOP: 19 mm2: 6.4 x 3(TSSOP) PKG
Special FeaturesTemp Monitoring (Thermistor Pin)
USB FeatureN/A
  • Evaluation Modules & Boards: DV2000S1
    BQ2000 Evaluation Module for Multi-Chemistry, switchmode
  • Evaluation Modules & Boards: BQ2000EVM
    Evaluation Module for Battery Charge Management IC
  • High Efficiency Dual Chemistry Charger Using the bq2000
    PDF, 130 Кб, Файл опубликован: 5 сен 1999
    In this example, the bq2000 is used to design a simple and cost-effective chemistry-independent charger. This implementation is suitable for any application requiring a high efficiency charge management in a small footprint.
  • Bq2000 in Constant Voltage Phase for Li-ion Battery
    PDF, 533 Кб, Файл опубликован: 31 окт 2011
    The bq2000 charger can be used to charge Li-Ion, NiCd, or NiMH batteries. It uses three charging modes, the pre-charge, fast charge, and termination mode. It detects the battery chemistry type during the fast charge mode by monitoring the battery voltage profile. Once the chemistry is determined, the part completes the fast charge algorithm for the appropriate chemistry type. For Li-Ion batteries,
  • U-504 Using the bq2000/T to Control Fast Charge (Rev. B)
    PDF, 193 Кб, Версия: B, Файл опубликован: 2 дек 2004
    The bq2000/T are programmable, monolithic ICs for fast-charge management of nickel cadmium, nickel metal-hydride, and lithium-ion batteries in single- or multichemistry applications. This application note discusses simple ways to select all necessary components to implement various switch-mode topologies. It also discusses how to configure the bq2000/T inputs to accomodate different appplication c
  • Battery Charger Termination Issues With System Load Applied Across Battery (Rev. A)
    PDF, 151 Кб, Версия: A, Файл опубликован: 2 окт 2006
    Battery Charger Termination Issues With System Load Applied Across Battery While Charging
  • Semiconductors > Power Management > Battery Management Products > Battery Charger IC
На английском языке: Datasheet Texas Instruments BQ2000PWG4
