Datasheet Texas Instruments 7604501FA — Даташит
Серия | SN54LS47 |
Модель | 7604501FA |
BCD-to-Seven-Segment Decoders/Drivers datasheet
PDF, 1.7 Мб, Файл опубликован: 1 мар 1988
LS SERIES, SEVEN SEGMENT DECODER/DRIVER, INVERTED OUTPUT, CDFP16, DFP-16 | |||
7604501FA Texas Instruments | по запросу | ||
Pin | 16 |
Channels(#) | 1 |
F @ Nom Voltage(Max)(Mhz) | 35 |
Operating Temperature Range(C) | -55 to 125 |
Package Group | CDIP LCCC |
Package Size: mm2:W x L (PKG) | See datasheet (CDIP) |
Rating | Military |
Schmitt Trigger | No |
Technology Family | LS |
VCC(Max)(V) | 5.5 |
VCC(Min)(V) | 4.5 |
Voltage(Nom)(V) | 5 |
RoHS | Не совместим |
- Input and Output Characteristics of Digital Integrated CircuitsPDF, 1.7 Мб, Файл опубликован: 1 окт 1996
This report contains a comprehensive collection of the input and output characteristic curves of typical integrated circuits from various logic families. These curves go beyond the information given in data sheets by providing additional details regarding the characteristics of the components. This knowledge is particularly useful when for example a decision must be made as to which circuit shou - Designing With Logic (Rev. C)PDF, 186 Кб, Версия: C, Файл опубликован: 1 июн 1997
Data sheets which usually give information on device behavior only under recommended operating conditions may only partially answer engineering questions that arise during the development of systems using logic devices. However information is frequently needed regarding the behavior of the device outside the conditions in the data sheet. Such questions might be:?How does a bus driver behave w - Designing with the SN54/74LS123 (Rev. A)PDF, 118 Кб, Версия: A, Файл опубликован: 1 мар 1997
Серия: SN54LS47 (6)
- 7604501EA 7604501FA SN54LS47J SNJ54LS47FK SNJ54LS47J SNJ54LS47W
- Semiconductors > Space & High Reliability > Logic Products > Specialty Logic Products > Decoders/Encoders/Multiplexers
