Datasheet Texas Instruments 5962-87681012A — Даташит
Серия | UC1825 |
Модель | 5962-87681012A |
Высокоскоростной ШИМ-контроллер 20-LCCC от -55 до 125
High Speed PWM Controller datasheet
PDF, 2.1 Мб, Версия: A, Файл опубликован: 24 фев 2004
Купить 5962-87681012A на РадиоЛоцман.Цены — от 5 171 до 12 145 ₽ 9 предложений от 9 поставщиков HIGH SPEED PWM CONTROLLER 20-LCC / Regulator Output DC-DC Controller IC | |||
5962-87681012A Texas Instruments | 5 171 ₽ | ||
5962-87681012A Texas Instruments | 6 057 ₽ | ||
UC1825L883B DM: 5962-87681012A | 12 145 ₽ | ||
5962-87681012A | по запросу |
Pin | 20 |
Package Type | FK |
Industry STD Term | LCCC |
JEDEC Code | S-CQCC-N |
Package QTY | 1 |
Carrier | TUBE |
Width (мм) | 8.89 |
Length (мм) | 8.89 |
Thickness (мм) | 1.83 |
Pitch (мм) | 1.27 |
Max Height (мм) | 2.03 |
Mechanical Data | Скачать |
Control Method | Current |
Duty Cycle(Max) | 80 % |
Основные особенности | Error Amplifier,Soft Start,Synchronization Pin,Multi-topology |
Frequency(Max) | 1000 kHz |
Frequency(Min) | 0.1 kHz |
Package Group | LCCC |
Package Size: mm2:W x L | 20LCCC: 79 mm2: 8.89 x 8.89(LCCC) PKG |
Rating | Military |
Topology | Boost,Flyback,Forward,Full-Bridge,Half-Bridge,Push-Pull |
UVLO Thresholds On/Off | 9.2/8.4 В |
Vin(Max) | 30 В |
Vin(Min) | 8.4 В |
RoHS | See ti.com |
- U-110 1.5 Mhz Current Mode IC Controlled 50-Watt Power SupplyPDF, 298 Кб, Файл опубликован: 5 сен 1999
The UC3825 family of PWM control ICs is optimized for high-frequency switched-mode power-supply applications. This application note describes the development of a 1.5 MHz current-mode IC-controlled 50W power supply. Push-pull topology is used for this DC-to-DC converter application of +48V input to +5V at 10A output. Increases in switching speed and dynamic performance are made possible by the U - U-111 Practical Considerations in Current Mode Power SuppliesPDF, 787 Кб, Файл опубликован: 5 сен 1999
This application note explains the numerous PWM functions and ways to maximize their usefulness. It covers practical circuit design considerations such as slope compensation gate drive circuitry external control functions synchronization and paralleling current-mode controlled modules. Circuit diagrams and simplified equations are included.
Серия: UC1825 (8)
- 5962-87681012A 5962-8768101EA 5962-8768101QFA UC1825J UC1825J883B UC1825L UC1825L883B UC1825W883B
- Semiconductors > Space & High Reliability > Power Management Products > Offline and Isolated DC/DC Controller and Converter
596287681012A, 5962 87681012A
